Install Conda
Conda Installation
Conda is an open-source package and environment management system, primarily used in data science, scientific computing, and machine learning fields.
Conda has two versions: Anaconda and Miniconda. This tutorial mainly introduces the installation and usage of Anaconda.
  • Anaconda: A complete distribution with a rich set of pre-installed packages.
  • Miniconda: A lightweight distribution that only includes Conda itself, requiring manual installation of additional packages.
Features of Conda​
  • Easy Management
Fully isolated Python environments managed with the conda command, automatically resolving dependencies.
  • Cross-Platform
Supports Windows, macOS, and Linux systems.
  • Portability
Supports exporting environment configurations, making it easy to replicate the same development environment on other machines.
  • Multi-Language Support
Supports multiple programming languages, not limited to Python.
Conda Installation​
Download Installation Script​
Visit the Anaconda Official Website to download the installation script for Linux ARM64.
Run Installation Script​
After downloading, navigate to the download directory, open a terminal, and run the installation script. Replace the script name with the actual downloaded file name.
bash Anaconda3-<version>-Linux-aarch64.sh
During installation, press Enter to proceed through the steps. Then type yes to accept the license agreement.
The terminal will display information similar to the following:
Welcome to Anaconda3 <version>
In order to continue the installation process, please review the license
agreement.
Please, press ENTER to continue
> > > By continuing installation, you hereby consent to the Anaconda Terms of Service available at https://anaconda.com/legal.
Do you accept the license terms? [yes|no]
> > > yes
Finally, you will be asked whether to initialize Conda automatically in the terminal. Type yes to confirm.
Verify Installation​
Reopen the terminal. If (base) appears before the username in the terminal prompt, it indicates that Conda has been successfully installed and initialized.
The base environment is Conda's default environment, which includes some commonly used tools for data science and machine learning.
Check Conda Version​
Open the terminal and use the conda --version command to check the Conda version:
conda --version
conda 24.9.2
Exit Conda Environment​
To exit the Conda environment, use the conda deactivate command.
conda deactivate
After exiting the Conda environment, the (base) prefix will disappear from the terminal prompt.
Configure Conda (Optional)​
Modify Conda's configuration to add Tsinghua University's mirror source for faster downloads in China (optional).
Generate Configuration File​
conda config --set show_channel_urls yes
Edit Configuration File​
vi ~/.condarc
Add the following content to the configuration file:
channels:
- defaults
show_channel_urls: true
default_channels:
- https://mirrors.tuna.tsinghua.edu.cn/anaconda/pkgs/main
- https://mirrors.tuna.tsinghua.edu.cn/anaconda/pkgs/r
- https://mirrors.tuna.tsinghua.edu.cn/anaconda/pkgs/msys2
custom_channels:
conda-forge: https://mirrors.tuna.tsinghua.edu.cn/anaconda/cloud
pytorch: https://mirrors.tuna.tsinghua.edu.cn/anaconda/cloud
Clear Cache​
Use the conda clean command to clear the cache and temporary files.
conda clean -i
Verify Configuration​
Open the terminal and use the conda config --show-sources command to view all loaded configuration files and their priority order.
If the configuration is successful, the terminal will display information similar to the following:
==> /home/radxa/anaconda3/.condarc <==
channels:
- defaults
==> /home/radxa/.condarc <==
channels:
- defaults
custom_channels:
default_channels:
show_channel_urls: True
==> envvars <==
allow_softlinks: False
