Install the System to eMMC
Note
This guide applies to Cubie A7S variants with onboard eMMC.
This guide explains how to install the system to eMMC using the dd command when the system can boot normally from a MicroSD card.
warning
Installing the system will format the eMMC. Please back up any important data in advance!
To use the dd command to install the system to eMMC, you need to meet the following conditions:
  • The system can boot normally from a MicroSD card
  • eMMC is installed on the board or the board has built-in eMMC
Hardware Connection​
If your board has onboard eMMC, no installation is required.
System Installation​
Download System Image​
Access the Resource Download page from your device and download the latest system image to the device.
Image Note
You can use the wget command to download the system image file to your device.
radxa@cubie-a7s$
sudo apt install wget -y
wget <download_url>
Where <download_url> is the download URL of the system image file. You can copy the image download URL from the Resource Download page to replace it.
Download example: wget https://github.com/radxa-build/radxa-a733/releases/download/rsdk-r6/radxa-a733_bullseye_kde_r6.output_512.img.xz
Extract System Image​
Our system images are generally in *.img.xz format and need to be extracted before use.
radxa@cubie-a7s$
sudo apt install xz-utils -y
unxz <path_to_image_unxz>
Where <path_to_image_unxz> is the path to the system image file, which needs to be replaced with the actual system image file path.
Extraction example:
unxz radxa-a733_bullseye_kde_r6.output_512.img.xz
Determine Device Path​
You can use the lsblk command to check the device path and determine it based on the disk capacity.
Note: If the disk capacities are similar, you can safely remove and reinsert the eMMC module (for eMMC modules) to observe which device path appears and disappears, thus determining the correct device path.
radxa@cubie-a7s$
lsblk
If the system recognizes the eMMC device, it will typically be identified as a /dev/mmcblk* device.
Terminal output example:
mmcblk1 179:0 0 29.1G 0 disk
└─mmcblk1p1 179:1 0 29.1G 0 part
Install System Image​
Use the dd command to install the system image to the eMMC.
radxa@cubie-a7s$
Write example:
sudo dd if=radxa-a733_bullseye_kde_r6.output_512.img of=/dev/mmcblk1 bs=4M status=progress
Parameter description:
  • <path_to_image>: The path to the system image file, which needs to be replaced with the actual system image file path.
  • <device_target>: The device path of the eMMC module, which needs to be replaced with the actual eMMC module's device path.
  • bs=4M: Block size for writing.
  • status=progress: Display write progress.
Verify Write Result​
After the system installation is complete, you can use the lsblk command to check if the eMMC partition table has been created correctly.
radxa@cubie-a7s$
lsblk
mmcblk0 179:0 0 29.1G 0 disk
├─mmcblk0p1 179:1 0 16M 0 part
├─mmcblk0p2 179:2 0 300M 0 part
└─mmcblk0p3 179:3 0 28.8G 0 part
Boot the system​
After installation, power off the board and disconnect power. Then follow the steps below to boot:
① Remove the microSD card from the board
② Connect a monitor using a USB‑C to HDMI/DP cable
③ Connect keyboard/mouse via USB‑A (use a USB hub if needed)
④ Power the board with a 5V USB‑C power adapter
If power is OK, the power LED turns green. If the system boots, the status LED blinks blue.
After booting successfully, you should see the desktop. Log in using the credentials below.
Default credentials​
For official system images:
ItemValue
Usernameradxa
Passwordradxa
Log in​
Log in with the default credentials.
Use the system​
After booting successfully, you can start using Radxa OS on Cubie A7S. See System configuration for basic usage.
