Radxa Camera 13M 214
Radxa Cubie A7Z's onboard MIPI CSI interface can be used to connect the Radxa Camera 13M 214 for image capture.
Interface specifications​
Camera interface​
The Radxa Camera 13M 214 interface has the following specifications:
Board MIPI CSI interface​
The Radxa Cubie A7Z MIPI CSI interface has the following specifications:
  • Connector type: 31-Pin 0.3 mm pitch SMD horizontal FPC connector
Camera FPC cable​
Hardware connection​
Notes
Software enablement​
Use the Rsetup tool provided by the Radxa system to enable the Radxa Camera 13M 214.
Rsetup usage guide
radxa@cubie-a7z$
rsetup
  1. Use the arrow keys to find the [ ] Enable Radxa Camera 13M 214 option.
  2. Press Space so it changes to [*] Enable Radxa Camera 13M 214, indicating that the feature is enabled.
If the board has multiple MIPI CSI interfaces, Rsetup may show options such as [ ] Enable Radxa Camera 13M 214 on CAM *. Select the option corresponding to the MIPI CSI interface you are using.
Install GStreamer​
radxa@cubie-a7z$
sudo apt-get update
Preview the camera​
Use GStreamer to preview the camera image.
radxa@cubie-a7z$
radxa@cubie-a7z$
DISPLAY=:0 gst-launch-1.0 v4l2src device=/dev/video1 en-awisp=1 en-largemode=1 ! video/x-raw,format=NV12,width=3840,height=2160,framerate=30/1 ! xvimagesink
radxa@cubie-a7z$
DISPLAY=:0 gst-launch-1.0 v4l2src device=/dev/video1 en-awisp=1 en-largemode=1 ! video/x-raw,format=NV12,width=4208,height=3120,framerate=30/1 ! xvimagesink
Verified setup and common pipelines​
The notes below summarize the Cubie A7Z results confirmed in issue #1360 and are intended as a quick validation baseline.
  • Verified image: radxa-a733_bullseye_kde_r2.output_512.img.xz
  • Full-resolution preview: use /dev/video1 at 4208x3120 with en-largemode=1
  • 1080p preview: use /dev/video0 at 1920x1080 with en-largemode=0
  • Lower resolutions were not fully validated in that software flow; switching directly to smaller resolutions may still produce abnormal output
radxa@cubie-a7z$
Troubleshooting​
  • If no /dev/video* nodes appear, first confirm that you are using a recent official image, then reseat the FPC cable and verify its orientation and latch state
  • To quickly confirm whether the camera has been detected by the kernel, run v4l2-ctl --list-devices
  • To reproduce the validated behavior documented here, start with the two verified pipelines above before trying unvalidated lower-resolution settings
