Ollama Installation
Ollama is a powerful local large language model (LLM) framework that enables users to efficiently run various open-source large language models on their own computers.
Ollama Features​
  • Cross-Platform Support
    Supports macOS, Linux, and Windows operating systems, meeting the needs of different user groups.
  • User-Friendly
    Provides a clean command-line interface that makes downloading, running, and managing large language models extremely convenient.
  • Extensive Model Support
    Supports running various open-source large language models, including popular ones like DeepSeek, Qwen, and LLama.
  • Local Execution
    All models run locally, ensuring data privacy and security without relying on cloud services.
  • High Performance
    Optimized for local environments, making full use of hardware resources to provide a smooth interactive experience.
  • Developer-Friendly
    Offers API interfaces, making it easy for developers to integrate models into their own applications.
Installing Ollama​
You can install Ollama using the official Linux installation script.
Open a terminal and run the following command to download and execute the installation script:
curl -fsSL https://ollama.com/install.sh | sh
The terminal will display the installation progress and information. Upon successful installation, you'll see output similar to the following:
> > > Installing ollama to /usr/local
> > > Downloading Linux arm64 bundle
> > > ######################################################################## 100.0%
> > > Creating ollama user...
> > > Adding ollama user to render group...
> > > Adding ollama user to video group...
> > > Adding current user to ollama group...
> > > Creating ollama systemd service...
> > > Enabling and starting ollama service...
> > > Created symlink /etc/systemd/system/default.target.wants/ollama.service → /etc/systemd/system/ollama.service.
> > > The Ollama API is now available at 127.0.0.1:11434.
> > > Install complete. Run "ollama" from the command line.
> > > WARNING: No NVIDIA/AMD GPU detected. Ollama will run in CPU-only mode.
Verifying Ollama Installation​
You can check the Ollama version information using the ollama -v command.
ollama -v
If the Ollama version number is displayed successfully, the installation was successful.
