Ollama Installation
Ollama is a powerful local large language model (LLM) framework that enables users to efficiently run various open-source large language models on their own computers.
Ollama Features
Cross-Platform Support
Supports macOS, Linux, and Windows operating systems, meeting the needs of different user groups.
User-Friendly
Provides a clean command-line interface that makes downloading, running, and managing large language models extremely convenient.
Extensive Model Support
Supports running various open-source large language models, including popular ones like DeepSeek, Qwen, and LLama.
Local Execution
All models run locally, ensuring data privacy and security without relying on cloud services.
High Performance
Optimized for local environments, making full use of hardware resources to provide a smooth interactive experience.
Developer-Friendly
Offers API interfaces, making it easy for developers to integrate models into their own applications.
Installing Ollama
You can install Ollama using the official Linux installation script.
Open a terminal and run the following command to download and execute the installation script:
curl -fsSL https://ollama.com/install.sh | sh
The terminal will display the installation progress and information. Upon successful installation, you'll see output similar to the following:
> > > Installing ollama to /usr/local
> > > Downloading Linux arm64 bundle
> > > ######################################################################## 100.0%
> > > Creating ollama user...
> > > Adding ollama user to render group...
> > > Adding ollama user to video group...
> > > Adding current user to ollama group...
> > > Creating ollama systemd service...
> > > Enabling and starting ollama service...
> > > Created symlink /etc/systemd/system/default.target.wants/ollama.service → /etc/systemd/system/ollama.service.
> > > The Ollama API is now available at 127.0.0.1:11434.
> > > Install complete. Run "ollama" from the command line.
> > > WARNING: No NVIDIA/AMD GPU detected. Ollama will run in CPU-only mode.
Verifying Ollama Installation
You can check the Ollama version information using the ollama -v
command.
ollama -v
If the Ollama version number is displayed successfully, the installation was successful.
