Video Codec
This document explains how to use GStreamer with OpenMAX components on Allwinner platforms for video decoding, encoding, and encode-decode loopback validation. It applies to Radxa Allwinner-based boards such as Radxa Cubie A5E, Radxa Cubie A7A, Radxa Cubie A7S, and Radxa Cubie A7Z running Debian desktop images.
Preparation​
Install GStreamer Tools​
sudo apt-get update
Check available OMX plugins​
gst-inspect-1.0 | grep omx
Compatibility note
The OMX elements available on the system may vary depending on the SoC and image version. It is recommended to run gst-inspect-1.0 | grep omx first and use the codec elements that are actually present on your board.
Display output note
The following examples assume a local desktop session, so they use DISPLAY=:0 together with xvimagesink.
If you are testing through SSH, serial console, or in a headless environment, you can remove DISPLAY=:0 and replace xvimagesink with fakesink or filesink to verify that the pipeline itself works.
Supported OpenMAX codecs​
Video decoders​
ElementDescription
omxavsvideodecOpenMAX AVS Video Decoder
omxh263videodecOpenMAX H.263 Video Decoder
omxh264decOpenMAX H.264 Video Decoder
omxhevcvideodecOpenMAX H.265 Video Decoder
omxmjpegvideodecOpenMAX MJPEG Video Decoder
omxmpeg1videodecOpenMAX MPEG1 Video Decoder
omxmpeg2videodecOpenMAX MPEG2 Video Decoder
omxmpeg4videodecOpenMAX MPEG4 Video Decoder
omxvp8videodecOpenMAX VP8 Video Decoder
omxvp9videodecOpenMAX VP9 Video Decoder
Video encoders​
ElementDescription
omxh264videoencOpenMAX H.264 Video Encoder
omxmjpegvideoencOpenMAX MJPEG Video Encoder
Example pipelines​
Decode and play an H.264 file​
The following example uses bbb_sunflower_1080p_60fps_normal.mp4 as the test file. If the file is not in the current directory, replace location with the actual path.
DISPLAY=:0 gst-launch-1.0 filesrc location=bbb_sunflower_1080p_60fps_normal.mp4 ! parsebin ! omxh264dec ! xvimagesink
Encode H.264 to a Matroska file​
The following pipeline uses videotestsrc to generate 600 frames, encodes them with the hardware H.264 encoder, and saves the result as test.mkv.
DISPLAY=:0 gst-launch-1.0 videotestsrc num-buffers=600 ! omxh264videoenc ! h264parse ! matroskamux ! filesink location=test.mkv
H.264 encode-decode loopback​
This example encodes a test pattern to H.264 and immediately decodes it for display. The pipeline runs continuously until you stop it with Ctrl+C.
DISPLAY=:0 gst-launch-1.0 videotestsrc ! omxh264videoenc ! omxh264dec ! xvimagesink
Compatibility note
The encode-decode loopback example above is temporarily available only on A733.
Usage notes​
  • If your input is not H.264, keep the same pipeline structure and replace omxh264dec with the matching OMX decoder, such as omxhevcvideodec for H.265 or omxvp9videodec for VP9.
  • parsebin automatically selects a demuxer and parser. If parsing fails for a specific file, you can switch to an explicit pipeline such as qtdemux ! h264parse or matroskademux ! h265parse.
  • To test MJPEG encoding, replace the encoder with omxmjpegvideoenc and choose an appropriate muxer, or write directly to JPEG sequence files if needed.
  • When using file output pipelines, let the pipeline exit normally whenever possible to avoid incomplete container metadata.
