Conda Usage
Common Conda Commands
This section introduces some commonly used Conda commands.
View Help​
Open the terminal and use the conda --help command to view the usage of all Conda commands.
conda --help
usage: conda [-h] [-v] [--no-plugins] [-V] COMMAND ...
conda is a tool for managing and deploying applications, environments and packages.
options:
-h, --help Show this help message and exit.
-v, --verbose Can be used multiple times. Once for detailed output, twice for INFO logging, thrice for DEBUG logging, four times for TRACE
logging.
--no-plugins Disable all plugins that are not built into conda.
-V, --version Show the conda version number and exit.
commands:
The following built-in and plugins subcommands are available.
COMMAND
activate Activate a conda environment.
build Build conda packages from a conda recipe.
clean Remove unused packages and caches.
commands List all available conda subcommands (including those from plugins). Generally only used by tab-completion.
compare Compare packages between conda environments.
config Modify configuration values in .condarc.
content-trust Signing and verification tools for Conda
convert Convert pure Python packages to other platforms (a.k.a., subdirs).
create Create a new conda environment from a list of specified packages.
deactivate Deactivate the current active conda environment.
debug Debug the build or test phases of conda recipes.
develop Install a Python package in 'development mode'. Similar to `pip install --editable`.
doctor Display a health report for your environment.
env Create and manage conda environments.
export Export a given environment
index Update package index metadata files.
info Display information about current conda install.
init Initialize conda for shell interaction.
inspect Tools for inspecting conda packages.
install Install a list of packages into a specified conda environment.
list List installed packages in a conda environment.
metapackage Specialty tool for generating conda metapackage.
notices Retrieve latest channel notifications.
pack See `conda pack --help`.
package Create low-level conda packages. (EXPERIMENTAL)
remove (uninstall) Remove a list of packages from a specified conda environment.
rename Rename an existing environment.
render Expand a conda recipe into a platform-specific recipe.
repo See `conda repo --help`.
repoquery Advanced search for repodata.
run Run an executable in a conda environment.
search Search for packages and display associated information using the MatchSpec format.
server See `conda server --help`.
skeleton Generate boilerplate conda recipes.
token See `conda token --help`.
tos A subcommand for viewing, accepting, rejecting, and otherwise interacting with a channel's Terms of Service (ToS). This plugin
periodically checks for updated Terms of Service for the active/selected channels. Channels with a Terms of Service will need to
be accepted or rejected prior to use. Conda will only allow package installation from channels without a Terms of Service or with
an accepted Terms of Service. Attempting to use a channel with a rejected Terms of Service will result in an error.
update (upgrade) Update conda packages to the latest compatible version.
View Version Information​
Open the terminal and use the conda --version command to check the Conda version.
conda --version
conda 24.9.2
View Current Environment​
Open the terminal and use the conda info command to view the current environment information.
conda info
     active environment : base
active env location : /home/radxa/anaconda3
shell level : 1
user config file : /home/radxa/.condarc
populated config files : /home/radxa/anaconda3/.condarc
conda version : 25.5.1
conda-build version : 25.5.0
python version : 3.13.5.final.0
solver : libmamba (default)
virtual packages : **archspec=1=aarch64
**conda=25.5.1=0
**glibc=2.36=0
**linux=5.15.147=0
\_\_unix=0=0
base environment : /home/radxa/anaconda3 (writable)
conda av data dir : /home/radxa/anaconda3/etc/conda
conda av metadata url : None
channel URLs : https://mirrors.tuna.tsinghua.edu.cn/anaconda/pkgs/main/linux-aarch64
https://mirrors.tuna.tsinghua.edu.cn/anaconda/pkgs/main/noarch
https://mirrors.tuna.tsinghua.edu.cn/anaconda/pkgs/r/linux-aarch64
https://mirrors.tuna.tsinghua.edu.cn/anaconda/pkgs/r/noarch
https://mirrors.tuna.tsinghua.edu.cn/anaconda/pkgs/msys2/linux-aarch64
https://mirrors.tuna.tsinghua.edu.cn/anaconda/pkgs/msys2/noarch
package cache : /home/radxa/anaconda3/pkgs
/home/radxa/.conda/pkgs
envs directories : /home/radxa/anaconda3/envs
/home/radxa/.conda/envs
platform : linux-aarch64
user-agent : conda/25.5.1 requests/2.32.3 CPython/3.13.5 Linux/5.15.147 debian/11.11 glibc/2.36 solver/libmamba conda-libmamba-solver/25.4.0 libmambapy/2.0.5 aau/0.7.1 c/. s/. e/.
UID:GID : 1001:1001
netrc file : None
offline mode : False
View All Environments​
Open the terminal and use the conda env list command to view all environments.
conda env list
The terminal will output information similar to the following, indicating that only the base environment exists:
# conda environments:
base * /home/radxa/anaconda3
Create Environment​
Create a New Environment​
conda create --name <env_name>
# Example: Create an environment named my_env
conda create --name my_env
Create the environment, the terminal will output information similar to the following, asking for confirmation to proceed.
Channels:
- defaults
Platform: linux-aarch64
Collecting package metadata (repodata.json): done
Solving environment: done
## Package Plan
environment location: /home/radxa/anaconda3/envs/my_env
Proceed ([y]/n)? y
Downloading and Extracting Packages:
Preparing transaction: done
Verifying transaction: done
Executing transaction: done
# To activate this environment, use
# $ conda activate my_env
# To deactivate an active environment, use
# $ conda deactivate
Create an Environment with a Specific Python Version​
conda create --name <env_name> python=<python_version>
# Example: Create a Python 3.9 environment named my_env_py39
conda create --name my_env_py39 python=3.9
Channels:
- defaults
## Package Plan
environment location: /home/radxa/anaconda3/envs/my_env_py39
added / updated specs: - python=3.9
The following packages will be downloaded:
package | build
_libgcc_mutex-0.1 | main 2 KB defaults
_openmp_mutex-5.1 | 51_gnu 1.4 MB defaults
bzip2-1.0.8 | h998d150_6 210 KB defaults
ca-certificates-2025.2.25 | hd43f75c_0 129 KB defaults
expat-2.7.1 | h419075a_0 161 KB defaults
libffi-3.4.4 | h419075a_1 140 KB defaults
libgcc-ng-11.2.0 | h1234567_1 1.3 MB defaults
libgomp-11.2.0 | h1234567_1 466 KB defaults
libstdcxx-ng-11.2.0 | h1234567_1 779 KB defaults
libxcb-1.17.0 | hf66535e_0 433 KB defaults
ncurses-6.4 | h419075a_0 1.1 MB defaults
openssl-3.0.16 | h998d150_0 5.2 MB defaults
pip-25.1 | pyhc872135_2 1.3 MB defaults
pthread-stubs-0.3 | hfd63f10_1 7 KB defaults
python-3.9.23 | h89e7a61_0 24.2 MB defaults
readline-8.2 | h998d150_0 381 KB defaults
setuptools-78.1.1 | py39hd43f75c_0 1.6 MB defaults
sqlite-3.45.3 | h998d150_0 1.5 MB defaults
tk-8.6.14 | hb5ae6a8_1 3.5 MB defaults
tzdata-2025b | h04d1e81_0 116 KB defaults
wheel-0.45.1 | py39hd43f75c_0 114 KB defaults
xorg-libx11-1.8.12 | hf66535e_1 928 KB defaults
xorg-libxau-1.0.12 | hf66535e_0 14 KB defaults
xorg-libxdmcp-1.1.5 | hf66535e_0 19 KB defaults
xorg-xorgproto-2024.1 | h998d150_1 582 KB defaults
xz-5.6.4 | h998d150_1 573 KB defaults
zlib-1.2.13 | h998d150_1 113 KB defaults
Total: 47.1 MB
The following NEW packages will be INSTALLED:
\_libgcc_mutex anaconda/pkgs/main/linux-aarch64::\_libgcc_mutex-0.1-main
\_openmp_mutex anaconda/pkgs/main/linux-aarch64::\_openmp_mutex-5.1-51_gnu
bzip2 anaconda/pkgs/main/linux-aarch64::bzip2-1.0.8-h998d150_6
ca-certificates anaconda/pkgs/main/linux-aarch64::ca-certificates-2025.2.25-hd43f75c_0
expat anaconda/pkgs/main/linux-aarch64::expat-2.7.1-h419075a_0
libgcc-ng anaconda/pkgs/main/linux-aarch64::libgcc-ng-11.2.0-h1234567_1
libgomp anaconda/pkgs/main/linux-aarch64::libgomp-11.2.0-h1234567_1
libstdcxx-ng anaconda/pkgs/main/linux-aarch64::libstdcxx-ng-11.2.0-h1234567_1
libxcb anaconda/pkgs/main/linux-aarch64::libxcb-1.17.0-hf66535e_0
ncurses anaconda/pkgs/main/linux-aarch64::ncurses-6.4-h419075a_0
openssl anaconda/pkgs/main/linux-aarch64::openssl-3.0.16-h998d150_0
pip anaconda/pkgs/main/noarch::pip-25.1-pyhc872135_2
pthread-stubs anaconda/pkgs/main/linux-aarch64::pthread-stubs-0.3-hfd63f10_1
python anaconda/pkgs/main/linux-aarch64::python-3.9.23-h89e7a61_0
readline anaconda/pkgs/main/linux-aarch64::readline-8.2-h998d150_0
setuptools anaconda/pkgs/main/linux-aarch64::setuptools-78.1.1-py39hd43f75c_0
sqlite anaconda/pkgs/main/linux-aarch64::sqlite-3.45.3-h998d150_0
tk anaconda/pkgs/main/linux-aarch64::tk-8.6.14-hb5ae6a8_1
tzdata anaconda/pkgs/main/noarch::tzdata-2025b-h04d1e81_0
wheel anaconda/pkgs/main/linux-aarch64::wheel-0.45.1-py39hd43f75c_0
xorg-libx11 anaconda/pkgs/main/linux-aarch64::xorg-libx11-1.8.12-hf66535e_1
xorg-libxau anaconda/pkgs/main/linux-aarch64::xorg-libxau-1.0.12-hf66535e_0
xorg-libxdmcp anaconda/pkgs/main/linux-aarch64::xorg-libxdmcp-1.1.5-hf66535e_0
xorg-xorgproto anaconda/pkgs/main/linux-aarch64::xorg-xorgproto-2024.1-h998d150_1
xz anaconda/pkgs/main/linux-aarch64::xz-5.6.4-h998d150_1
zlib anaconda/pkgs/main/linux-aarch64::zlib-1.2.13-h998d150_1
Proceed ([y]/n)? y
# $ conda activate my_env_py39
Activate Environment​
conda activate <env_name>
# Example: Activate the my_env_py39 environment
After activating the environment, the terminal prompt will change to indicate the current conda environment.
Deactivate Environment​
conda deactivate
Delete Environment​
conda remove --name <env_name> --all
# Example: Delete the my_env_py39 environment
conda remove --name my_env_py39 --all
After deleting the environment, the terminal will output information similar to the following, asking for confirmation to proceed with the deletion.
