Docker Usage
This section demonstrates how to use Docker through common commands.
Image: An image is a read-only template that contains the application and its runtime environment (including dependencies, libraries, configuration files, etc.).
Container: A container is a running instance of an image, providing an executable environment based on the image. It includes the application and all dependencies but is isolated from the host system.
View Help​
You can use Docker's built-in help command to view the usage of all Docker commands.
docker --help
Options:
-D, --debug Enable debug mode
Management Commands:
builder Manage builds
config Manage Docker configs
container Manage containers
context Manage contexts
image Manage images
network Manage networks
node Manage Swarm nodes
plugin Manage plugins
secret Manage Docker secrets
service Manage services
stack Manage Docker stacks
swarm Manage Swarm
system Manage Docker
volume Manage volumes
Commands:
create Create a new container
images List images
ps List containers
rename Rename a container
rmi Remove one or more images
To get more help with Docker, check out our guides at https://docs.docker.com/go/guides/
View Docker System Information​
Use the docker info command to view Docker system information, including Docker version, system configuration, storage driver, network configuration, etc.
docker info
Client:
Context: default
Debug Mode: false
Server:
Containers: 0
Running: 0
Paused: 0
Stopped: 0
Images: 1
Storage Driver: overlay2
Backing Filesystem: extfs
Supports d_type: true
Native Overlay Diff: true
userxattr: false
Logging Driver: json-file
Cgroup Driver: systemd
Cgroup Version: 2
Plugins:
Volume: local
Swarm: inactive
Default Runtime: runc
Init Binary: docker-init
init version:
Security Options:
seccomp
Profile: default
cgroupns
OSType: linux
Architecture: aarch64
CPUs: 8
Total Memory: 3.829GiB
Debug Mode: false
Labels:
Experimental: false
Insecure Registries:
127.0.0.0/8
Live Restore Enabled: false
View Version Information​
To view only the Docker version information, use the docker --version command.
docker --version
Pull an Image​
Use the docker pull command to pull an image from the cloud (Docker Hub by default).
docker pull <image_name>
# Example: Pull the latest hello-world image
docker pull hello-world
After successfully pulling the image, the terminal will output information similar to the following:
Using default tag: latest
c9c5fd25a1bd: Pull complete
Run a Container​
If the image is not available locally, Docker will automatically pull the image from the cloud and then run the container.
docker run <image_name>
# Example: Run the latest hello-world image
docker run hello-world
After successfully running the container, the terminal will output information similar to the following:
Hello from Docker!
(arm64v8)
to your terminal.
$ docker run -it ubuntu bash
https://hub.docker.com/
Run a Container in Interactive Mode​
In interactive mode, the container remains running, and you can directly operate the container in the terminal until you type exit to exit the container.
# Example: Run the ubuntu:24.04 image in interactive mode
After successfully running the container, the terminal will output information similar to the following, where 8a18a7ee0838 is the container ID:
root@8a18a7ee0838:/#
Type exit inside the container to exit.
Access the Same Container from Multiple Terminals​
# Example: Access the container with ID 8a18a7ee0838
View Images​
docker images
View Containers​
docker ps -a
The terminal will output information similar to the following. You can determine whether a container is running based on the status field:
Save a Container​
If you have made changes to a running container, you can use the docker commit command to save the container as an image for future use.
# Example: Save the container with ID 8a18a7ee0838 as the ubuntu_24_v1 image
After successfully saving, the terminal will output information similar to the following:
Stop a Container​
If you are inside a running container, type exit to stop the container.
If you are not inside the container, use the docker stop command to stop it.
docker stop <container_id>
# Example: Stop the container with ID 8a18a7ee0838
docker stop 8a18a7ee0838
After successfully stopping the container, the terminal will output information similar to the following:
8a18a7ee0838
Clean Up Containers​
This command only cleans up stopped containers and does not affect running containers.
docker container prune
The terminal will output information similar to the following. You need to type y to confirm:
Deleted Containers:yun3
Total reclaimed space: 5B
Delete an Image​
Use the docker rmi command to delete an image.
docker rmi <image_name>
# Example: Delete the ubuntu:24.04 image
docker rmi ubuntu:24.04
After successfully deleting the image, the terminal will output information similar to the following:
Untagged: ubuntu:24.04
