VS Code Remote SSH Development
VS Code Remote SSH Guide​
This document describes how to use Visual Studio Code (VS Code) + Remote SSH to connect from your local machine to a Radxa SBC for development. With this setup, you can keep using your familiar local IDE while building, running, and debugging on the real Radxa SBC hardware.
Applicable Scenarios​
  • Target device: Radxa SBC (running Radxa OS / Debian / Ubuntu, etc.)
  • Local development host: Windows / macOS / Linux
  • Use cases: need to access real hardware resources such as GPIO, peripherals, and on-board network
How It Works​
VS Code connects to the Radxa SBC over SSH and automatically deploys VS Code Server on the remote side:
  • Editor UI: runs on your local machine
  • Code storage, build, and debug: run on the SBC
  • File system: directly uses the SBC file system
Preparation​
Local Environment​
  • VS Code is installed
  • Your local machine can reach the Radxa SBC over the network (same LAN or routable IP)
Radxa SBC Environment​
  • System has booted and you can log in
  • Network is configured (can access Internet or LAN)
  • SSH service is available
Enable SSH on the Radxa SBC​
Start the SSH service​
On most systems, the service name is ssh:
sudo systemctl enable --now ssh
sudo systemctl status ssh
Get the SBC IP address​
ip a
Record the SBC IP address; you will need it later in VS Code.
Get SBC IP address
Serial console recommendation​
In the following situations, a serial console is an essential recovery method:
  • Network configuration errors
  • SSH connection failures
  • Firewall misconfiguration
  • Some platforms do not support tty display output at the moment
When troubleshooting SSH/network issues, it is highly recommended to log in to the SBC via serial console first.
Install VS Code "Remote - SSH" Extension (Local)​
  1. Open VS Code
  2. Go to the Extensions view
  3. Search for and install the Remote - SSH extension
Install Remote SSH extension in VS Code
Configure SSH Connection​
  1. Press Ctrl + Shift + P (macOS: Cmd + Shift + P)
  2. Select Remote-SSH: Add New SSH Host...
  3. Enter the SSH command, for example:
    Host$
    ssh radxa@<SBC_IP>
  4. Choose to save it to ~/.ssh/config
Option 2: Manually edit SSH config file​
Edit ~/.ssh/config:
Host$
nano ~/.ssh/config
Example configuration:
Host$
Host radxa-sbc
HostName 192.168.1.88
User radxa
Port 22
Select SSH host
  1. Generate an SSH key on your local machine:
    Host$
    ssh-keygen -t ed25519
  2. Copy the public key to the SBC:
    Host$
    ssh-copy-id radxa@<SBC_IP>
  3. Verify that you can log in without a password:
    Host$
    ssh radxa@<SBC_IP>
Connect to Radxa SBC from VS Code​
  1. In VS Code, press Ctrl + Shift + P
  2. Select Remote-SSH: Connect to Host...
  3. Choose the host you configured (for example, radxa-sbc)
On the first connection, VS Code automatically installs VS Code Server on the SBC. Just wait for the installation to complete.
VS Code connected to SBC
Open a Remote Project Folder​
  1. In the remote VS Code window, choose File → Open Folder...
  2. Select a project directory on the SBC, for example:
    /home/radxa/Dev/project
  3. Confirm, and VS Code will load the directory as the remote workspace.
Open remote folder
Remote Terminal and Port Forwarding​
Remote terminal​
In the remote VS Code window, open a terminal. It is already connected to the SBC:
uname -a
Port forwarding​
When a web service or debug service is running on the SBC, you can use VS Code Port Forwarding to forward the port to your local machine, making it easy to access from a browser or debugging tools.
Port forwarding
Troubleshooting​
VS Code Server installation fails​
On the SBC, remove the old VS Code Server directory and reconnect:
rm -rf ~/.vscode-server
Then, in the Remote SSH extension settings on your local machine, search for Remote.SSH: Use Local Server Download and set it to always.
SSH connection is unstable​
In your local ~/.ssh/config, add the following for the corresponding host:
Host$
ServerAliveInterval 30
ServerAliveCountMax 3
This helps reduce unexpected disconnections when the network is unstable.
SSH cannot connect at all​
Use a serial cable to connect to the SBC, log in, and then check and fix the network and SSH configuration.
  • Use a unified project root on the SBC, for example: /home/radxa/Dev
  • Separate build directories from source directories as much as possible
  • Use systemd to manage long-running services
  • Before changing network or SSH-related settings, make sure serial access is ready so you can recover quickly if something goes wrong
