40-Pin GPIO Interface
The Radxa Cubie A7Z features an onboard 40-Pin GPIO (General Purpose Input/Output) interface, providing highly flexible interface support for hardware expansion.
Users can connect various sensors, actuators, communication modules, displays, and other embedded peripherals through the 40-Pin GPIO interface, enabling rapid prototyping and functional validation in fields such as IoT, robotics control, and industrial automation.
danger
When using the 40-Pin GPIO interface, please pay attention to pin connections and peripheral wiring. Ensure correct pin connections as improper operation may cause hardware damage.
GPIO Features​
Cubie A7Z supports connecting external devices to the onboard GPIO pins, including UART, SPI, I2C, ADC, and more.
Function8Function7Function6Function5Function4Function3Function2Function1Pin#Pin#Function1Function2Function3Function4Function5Function6Function7Function8Function9
3.3V
1
2
5V
PJ-EINT23TWI11-SDATWI3-SDATWI7-SDAUART2-CTSUART3-RXPWM1-5PJ23
3
4
5V
PJ-EINT23TWI11-SCKTWI3-SCKTWI7-SCKUART2-RTSUART3-TXPWM1-4PJ22
5
6
GND
PB-EINT1JTAG-MSSPI2-CS0UART0-TXUART2-TXPB0
7
8
PB9UART0-TXI2S0-DIN2I2S0-DOUBT2PWM1-1WATCHDOG-SIGTWI8-SCKTWI0-SCKPB-EINT9
GND
9
10
PB10UART0-RXI2S0-DIN3I2S0-DOUBT3PWM1-2PLL-LOCK-DBGTWI8-SDATWI0-SDAPB-EINT10
PB-EINT1JTAG-CKSPI2-CLKUART0-RXUART2-RXPB1
11
12
PB5I2S0-BCLKSPI2-CS2PWM0-1TRACE-DATA0TWI1-SDAPB-EINT5
PL-EINT6S-PWM0-4S-IR-RXS-SPI0-MOSIS-UART0-TXS-JTAG-DOPL6
13
14
GND
PL-EINT7S-PWM0-5S-SPI0-MISOS-UART0-RXS-JTAG-DIPL7
15
16
PJ24PWM1-6UART4-TXTWI4-SCKSPI3-CLKPJ-EINT24
3.3V
17
18
PJ25PWM1-7UART4-RXTWI4-SDASPI3-MOSIPJ-EINT25
PD-EINT12PWM1-2SPI1-MOSIEINK-D12DSI1-D1PLVDS1-D1PPD12
19
20
GND
PD-EINT13PWM1-3SPI1-MISOEINK-D13DSI1-D1NLVDS1-D1NPD13
21
22
PL5S-JTAG-CKS-TWI2-SDAS-SPI0-CLKS-PWM0-3PL-EINT5
PD-EINT11PWM1-1SPI1-CLKEINK-D11DSI1-D0NLVDS1-D0NPD11
23
24
PD10LVDS1-D0PDSI1-D0PEINK-D10SPI1-CS0PWM1-0PD-EINT10
GND
25
26
PD14LVDS1-D2PDSI1-CKPEINK-D14SPI1-HOLDUART3-RTSPD-EINT14
PD-EINT17UART3-RXTWI2-SDAEINK-LEHDSI1-D2NLVDS1-CKNPD17
27
28
PD16LVDS1-CKPDSI1-D2PEINK-OEHTWI2-SCKUART3-TXPD-EINT16
PB-EINT2TWI0-SCKJTAG-DOHDMI-SCLSPI2-MOSIUART2-RTSPB2
29
30
GND
PB-EINT3TWI0-SDAJTAG-DIHDMI-SDASPI2-MISOUART2-CTSPB3
31
32
PM5S-UART0-RXS-TWI2-SDAS-TWI1-SDAS-UART1-RXS-PWM0-1S-IR-RXPM-EINT5
PM-EINT3S-PWM0-5S-UART1-RXS-UART0-RXS-SPI0-MISOS-JTAG-DIPM3
33
34
GND
PB-EINT6TRACE-DATA1PWM0-8PWM0-2SPI2-CS3I2S0-LRCKCLK-FANOUT1PB6
35
36
PB4PWM0-0I2S0-MCLKSPI2-CS1HDMI-CECTRACE-CLKTWI1-SCKPB-EINT4
PM-EINT4S-IR-RXS-PWM0-0S-UART1-TXS-TWI1-SCKS-TWI2-SCKS-UART0-TXPM4
37
38
PB8CLK-FANOUT3I2S0-DIN0I2S0-DOUBT1PWM1-0OWA0-OUTTRACE-DATA3TWI1-SDAPB-EINT8
GND
39
40
PB7CLK-FANOUT2I2S0-DOUBT0I2S0-DIN1PWM0-9OWA0-INTRACE-DATA2TWI1-SCKPB-EINT7
GPIO Pin Numbering​
To control a specific pin, you need to calculate the pin number using the following formula:
GPIO ChipPin RangeCalculation Formula
GPIOCHIP0A ~ KNUM + 32 * (A ~ K)
GPIOCHIP1L ~NUM + 32 * (L ~ )
Calculation Example:
  • PB7
GPIOCHIP0 -> 7 + 32 * (A ~ K) -> 7 + 32 * 1 -> 39
GPIO Usage​
Through the 40-Pin GPIO interface, demonstrate common GPIO usage.
Overlay Notes​
On Cubie A7Z, the same peripheral function can usually be routed to multiple pins, so the rsetup Overlay -> Manage overlays page only exposes a few common example overlays instead of every possible pinmux combination.
If you need to move PWM, UART, I2C, SPI, or other functions to different pins listed in the table above, use this workflow:
  1. Use the GPIO multiplexing table above to confirm the target function and target pin
  2. Try the built-in overlay examples in rsetup first
  3. If the built-in options do not cover your target pin, adapt an overlay by following the examples in radxa-overlays
  4. After editing, install your custom DTS / DTBO from rsetup -> Overlay -> Install 3rd party overlay
This keeps rsetup practical for common cases while still letting you extend the pinmux to other pins when your project needs it.
Install python-periphery​
Use the python-periphery library to control GPIO pins.
radxa@cubie-a7z$
sudo pip3 install python-periphery
GPIO Input​
Hardware Preparation​
  • Board
  • Dupont wire
Software Preparation​
The following code is used to read the high and low level of the PK4 pin using the python-periphery library.
gpio_input.py
from periphery import GPIO
import time
def read_gpio_input():
# Configure GPIO input (modify pin number according to actual hardware)
# Using pin 39 of /dev/gpiochip0 here (corresponds to PB7)
try:
# Initialize GPIO in input mode
gpio_in = GPIO("/dev/gpiochip0", 39, "in")
print("Starting GPIO input reading (press Ctrl+C to exit)")
while True:
# Read pin value
value = gpio_in.read()
print(f"GPIO input value: {value} (True=High, False=Low)")
time.sleep(1) # Read once per second
except KeyboardInterrupt:
print("\nProgram exited")
except Exception as e:
print(f"Error occurred: {e}")
finally:
# Ensure resources are released
try:
gpio_in.close()
except:
pass
if __name__ == "__main__":
read_gpio_input()
Test Steps​
  1. Connect the PB7 pin to the GND or 3.3V pin
  2. Save the code as gpio_input.py
  3. Run the test code using python3 gpio_input.py
Experimental Phenomenon​
The terminal will output False or True information.
False represents a low level, True represents a high level.
GPIO Output​
  • Board
  • Dupont wire
Test Code​
The following code is used to control the PB7 pin to output high and low levels, and then read the high and low levels of the PB7 pin through the PB8 pin.
gpio_output.py
import time
# PB7 (output) → maps to pin 39 of /dev/gpiochip0
# PB8 (input) → maps to pin 40 of /dev/gpiochip0
OUTPUT_PIN_CHIP = "/dev/gpiochip0"
OUTPUT_PIN_NUMBER = 39 # PB7 (output pin, controlled by the script)
INPUT_PIN_NUMBER = 40 # PB8 (input pin, reads PB7's output state)
gpio_out = None
gpio_in = None
try:
# Initialize PB7 as OUTPUT mode
# Initialize PB8 as INPUT mode
print(f"Controlled Pin (PB7): {OUTPUT_PIN_CHIP} - Pin {OUTPUT_PIN_NUMBER} (OUTPUT)")
print(f"Monitoring Pin (PB8): {OUTPUT_PIN_CHIP} - Pin {INPUT_PIN_NUMBER} (INPUT)")
print("Test Behavior: PB7 toggles HIGH/LOW every 1s; PB8 verifies PB7's state")
# Main loop: Toggle PB7 and read PB8 feedback
while True:
# 1. Set PB7 to HIGH level
gpio_out.write(True)
pb8_reading = gpio_in.read()
print(f"PB7 Output: HIGH (True) | PB8 Reading: {pb8_reading}")
# Keep PB7 HIGH for 1 second
time.sleep(1)
# 2. Set PB7 to LOW level
gpio_out.write(False)
print(f"PB7 Output: LOW (False) | PB8 Reading: {pb8_reading}")
# Keep PB7 LOW for 1 second
time.sleep(1)
finally:
# Safely close PB7 (set to LOW first to avoid residual high level)
if gpio_out:
try:
gpio_out.close()
print(f"Successfully closed PB7 (Pin {OUTPUT_PIN_NUMBER})")
print(f"Failed to close PB7 (Pin {OUTPUT_PIN_NUMBER}): {str(close_err)}")
# Safely close PB8
if gpio_in:
try:
gpio_in.close()
print(f"Successfully closed PB8 (Pin {INPUT_PIN_NUMBER})")
print(f"Failed to close PB8 (Pin {INPUT_PIN_NUMBER}): {str(close_err)}")
Test Steps​
  1. Short the PB7 pin and PB8 pin
  2. Save the code as gpio_output.py
  3. Run the test code using sudo python3 gpio_output.py
PWM Output​
  • Board
  • LED
  • Dupont wire
Test Code​
The following code is used to test PWM output using the python-periphery library.
pwm_output.py
from periphery import PWM
import time
def pwm_test():
try:
# Configure PWM parameters - modify according to your hardware
# Common PWM paths: /sys/class/pwm/pwmchip0/pwm0, etc.
PWM_CHIP = 10 # PWM chip number
PWM_CHANNEL = 2 # PWM channel number
# Initialize PWM
pwm = PWM(PWM_CHIP, PWM_CHANNEL)
print(f"PWM Test: Using PWM{PWM_CHIP}.{PWM_CHANNEL} (Pin: PD12)")
# Set PWM frequency to 1kHz
frequency = 1000 # 1000 Hz
pwm.frequency = frequency
print(f" Set frequency: {frequency} Hz")
# Enable PWM output
pwm.enable()
print(" PWM enabled")
# Test different duty cycles (0% to 100%)
duty_cycles = [0.0, 0.25, 0.5, 0.75, 1.0]
for duty in duty_cycles:
pwm.duty_cycle = duty
print(f" Set duty cycle: {duty*100:.1f}%")
time.sleep(1) # Maintain current duty cycle for 1 second
# Cleanup
pwm.disable()
pwm.close()
print(" PWM disabled and closed")
print("PWM Test completed successfully")
print(f"PWM Test failed: {e}")
print("Starting PWM Signal Test...\n")
pwm_test()
Test Steps​
  1. Enter rsetup -> Overlay -> Manage overlays and check the Enable PWM1-2 option, then restart the system
  2. Connect the positive terminal of the LED to the PD12 pin
  3. Connect the negative terminal of the LED to the GND pin
  4. Save the code as pwm_output.py
  5. Run the test code using sudo python3 pwm_output.py
The connected LED will flash with different brightness, from bright to dark.
UART Usage​
UART(Universal Asynchronous Receiver/Transmitter) is a widely used serial communication protocol, used for asynchronous serial data transmission between embedded systems, computers, and peripherals.
  • Board
  • Dupont wire
Test Code​
The following code is used to test UART4 loopback communication using the python-periphery library.
uart_example.py
from periphery import Serial
import time
def uart_test():
try:
# Modify the serial device path according to your hardware, common paths include /dev/ttyS0, /dev/ttyS1, /dev/ttyUSB0, etc.
# PJ24(TX) PJ25(RX)
UART_DEVICE = "/dev/ttyAS4"
BAUDRATE = 115200
# Initialize serial port
serial = Serial(UART_DEVICE, BAUDRATE)
print(f"UART Test: Opening serial port {UART_DEVICE}, baud rate {BAUDRATE}")
# Send test data
test_message = "Hello, UART Test!\n"
serial.write(test_message.encode())
print(f" Sent data: {test_message.strip()}")
# Wait for data transmission
time.sleep(0.1)
# Try to read data (if loopback or other device responds)
if serial.input_waiting() > 0:
received_data = serial.read(serial.input_waiting())
print(f" Received data: {received_data.decode().strip()}")
else:
print(" No data received (normal unless loopback is connected)")
serial.close()
print("UART test completed")
print(f"UART test failed: {e}")
uart_test()
Test Steps​
  1. Enter rsetup -> Overlay -> Manage overlays and check the Enable UART4 option, then restart the system
  2. Short the PJ24 pin and PJ25 pin
  3. Save the code as uart_example.py
  4. Run the test code using sudo python3 uart_example.py
The terminal will output the sent and received information, and you can judge whether the UART loopback test is successful based on the terminal output information.
I2C Usage​
I2C is a widely used synchronous serial communication protocol developed by Philips (now NXP), mainly used for short-distance chip-to-chip communication.
  • Board
  • I2C device (e.g., OLED display, its corresponding I2C address is 0x3C)
  • Dupont wire
Test Code​
The following code is used to test I2C communication using the python-periphery library.
i2c_example.py
from periphery import I2C
def i2c_device_detection():
"""I2C Test - Check if device exists
Pin reference: PJ23 (SDA), PJ22 (SCL)
# Modify according to your hardware connection
# Common I2C bus devices: /dev/i2c-0, etc.
I2C_BUS = "/dev/i2c-7"
TARGET_ADDR = 0x3C # Target address to check
i2c = None # Initialize I2C object reference
try:
i2c = I2C(I2C_BUS)
# Attempt a simple read/write operation to detect device
# Sending a single 0x00 byte as test communication
msgs = [I2C.Message([0x00])]
i2c.transfer(TARGET_ADDR, msgs)
print(f"I2C Test: Device found at address 0x{TARGET_ADDR:02X}")
return True
# Exception (e.g., IOError) usually indicates no device or no response
print(f"I2C Test: No device or no response at address 0x{TARGET_ADDR:02X}: {e}")
return False
finally:
# Ensure I2C resources are released
if i2c is not None:
try:
i2c.close()
except:
pass
print("Starting I2C Device Detection...")
print("I2C Test completed")
Test Steps​
  1. Enter rsetup -> Overlay -> Manage overlays and check the Enable TWI7 option, then restart the system
  2. Connect the SCL pin of the OLED display to the PJ22 pin, connect the SDA pin of the OLED display to the PJ23 pin, connect the VCC to 5V, and connect the GND to GND
  3. Save the code as i2c_example.py
  4. Run the test code using sudo python3 i2c_example.py
The script function is to check if a specific I2C device exists on the specified I2C bus, and can determine if the I2C device is working normally.
SPI Usage​
SPI (Serial Peripheral Interface) is a high-speed, full-duplex, synchronous serial communication protocol developed by Motorola (now NXP), mainly used for short-distance chip-to-chip communication, commonly used in data transmission between sensors, storage devices (such as Flash), and displays.
  • Board
  • Dupont wire
Test Code​
The following code is used to test SPI loopback communication using the python-periphery library.
spi_example.py
from periphery import SPI
def spi_communication_test():
# Data to be transmitted (4 bytes)
transmit_data = [0xAA, 0xBB, 0xCC, 0xDD]
try:
# Initialize SPI resource
# Parameters: SPI device path, mode 0, 1MHz clock frequency
spi = SPI("/dev/spidev1.0", 0, 1000000)
# Transmit data and receive response simultaneously
# SPI is full-duplex, so data is sent and received at the same time
received_data = spi.transfer(transmit_data)
# Print test results
print("SPI Test:")
print(" Transmitted data: [0x{:02x}, 0x{:02x}, 0x{:02x}, 0x{:02x}]".format(*transmit_data))
print(" Received data: [0x{:02x}, 0x{:02x}, 0x{:02x}, 0x{:02x}]".format(*received_data))
print(f"SPI Test failed: {e}")
finally:
# Ensure SPI resource is released
try:
spi.close()
except:
pass
print("Starting SPI Communication Test...\n")
print("\nSPI Test completed")
Test Steps​
  1. Enter rsetup -> Overlay -> Manage overlays and check the Enable spidev on SPI1 option, then restart the system
  2. Connect the PD12 pin and PD13 pin
  3. Save the code as spi_example.py
  4. Run the test code using sudo python3 spi_example.py
The terminal will output the sent and received information, and you can judge whether the SPI loopback test is successful based on the terminal output information.
