USB Type-C Interface
The Radxa Cubie A7Z features one USB 2.0 Type-C and one USB 3.1 Type-C port.
  • USB 2.0 Type-C
    • Power Supply: Supports 5V power input
    • Data Transfer: Supports USB OTG and FEL mode for firmware updates
  • USB 3.1 Type-C
    • Display: Supports DisplayPort Alt Mode
Interface Location
For the specific location of the USB Type-C ports, please refer to the interface description section in the Hardware Interface tutorial!
Usage Guide​
USB 2.0 Type-C​
Normal Use: Power the device using a 5V Type-C power adapter (recommended 3A or higher).
Firmware Update Mode: Connect the board to a PC using a USB Type-C data cable for both power supply and data transfer.
USB 3.1 Type-C​
Normal Use: Connect USB flash drives and other devices to the USB Type-C port for data transfer.
Display Function: Connect to a display using a USB Type-C cable, supporting DisplayPort Alt Mode.
OTG Mode: Enable OTG mode through Rsetup.
USB-C Power Port as Host Mode​
The USB-C Power port (interface ①, USB-C 2.0 OTG & Power) on the A7Z works in device mode by default. To connect peripherals such as wireless mouse receivers, keyboards, or USB flash drives, you need to switch it to host mode using a device tree overlay.
Step 1: Create the Overlay File​
A device tree overlay is required to switch the USB-C Power port to host mode. Below is a minimal configuration example:
/dts-v1/;
/plugin/;
compatible = "allwinner,sun50i-a733";
&usbc0 {
usb_port_type = <0x1>; /* 0x0: device, 0x1: host */
info
The usb_port_type setting controls the USB-C port role: setting it to 0x1 enables host mode, allowing connection of mouse, keyboard, USB flash drive, and other peripherals.
Step 2: Install the Overlay​
Place the prepared dts file in any directory, then install it using rsetup:
sudo rsetup
# Select Overlays → Install 3rd Party overlay → Select the corresponding dts file
rsetup will automatically compile the selected dts file and enable it. A system reboot is required after enabling the overlay for it to take effect.
Step 3: Reboot the System​
sudo reboot
Step 4: Verify​
lsusb
If the connected device appears in the output, host mode has been successfully enabled.
Compatibility
This method also applies to the Cubie A7S board.
