Radxa OS Development
Prerequisites
You need to have Visual Studio Code and Docker environment set up in advance, then use Dev Container to run the RadxaOS SDK (rsdk) compilation environment.
You can follow the tutorial below to complete the environment setup for RadxaOS SDK (rsdk) development.
Download rsdk Source Code
Use the git clone
command to clone the RadxaOS SDK (rsdk) source code.
git clone --recurse-submodules <git_repo_url>
Replace <git_repo_url>
with: https://github.com/RadxaOS-SDK/rsdk.git
Start Development Environment
Open the Radxa OS SDK (rsdk) source code directory with Visual Studio Code: The Dev Container
extension will usually automatically detect the configuration file in the folder and prompt you to reopen in the container development environment.
When starting the development environment for the first time, Dev Containers will automatically download and install dependencies. Please be patient as this may take some time.
- Click the
Remote
option in the bottom-left corner - Select the
Reopen in Container
option
Compile Radxa OS
After starting the development environment, use the rsdk
command to run the TUI interface.
rsdk
┌─────────────────┤ RSDK ├──────────────────┐
│ Please select a task: │
│ Build system image │
│ About │
│ <Ok> <Cancel> │
Select the Build system image
option to further choose the target board model you want to build for.
│ Please select a product: │
│ (*) radxa-cubie-a7z │
│ <Ok> <Cancel> │
After selecting yes
, the Radxa OS build process will start, and rsdk will automatically complete the image compilation.
┌─────────────────┤ RSDK ├───────────────────────┐
│ Are you sure to build for 'radxa-cubie-a7z'? │
│ <Yes> <No> │
After compilation is complete, a folder corresponding to the board model and system version will be generated in the out
directory, containing the Radxa OS image named output.img
