WiFi Usage
This guide explains how to connect to a WiFi network, set up a WiFi hotspot, and test network bandwidth.
- Connecting to a WiFi Network
When the board connects to a WiFi network, it typically obtains an IP address automatically through the router's DHCP service.
- Setting Up a WiFi Hotspot
When the board is set up as a WiFi hotspot (AP mode), the system usually starts a DHCP service automatically to assign IP addresses to connected devices. If you need to customize network parameters, you can manually configure the DHCP service as needed.
We'll use the nmcli
command-line tool to connect to a WiFi network.
nmcli (NetworkManager Command Line Interface) is a command-line tool for NetworkManager, used to configure and manage network connections on Linux systems.
Enabling WiFi
sudo nmcli radio wifi on
Scanning for WiFi Networks
If WiFi is enabled but no networks are found, you may need to restart the system.
sudo nmcli device wifi list
sudo nmcli device wifi connect <SSID> password <PASSWORD>
# Example
sudo nmcli device wifi connect wifi-demo password 12345678
Upon successful connection, the terminal will display output similar to:
Device 'wlan0' successfully activated with 'xxxxxx'.
Viewing Network Connection Details
ip a
The terminal will display output similar to the following, where 192.168.31.53
is the IP address assigned by the router:
inet6 ::1/128 scope host
link/sit 0.0.0.0 brd 0.0.0.0
valid_lft 3432sec preferred_lft 3432sec
inet6 240e:3b7:3246:1e0::b09/128 scope global dynamic noprefixroute
valid_lft 3383sec preferred_lft 3383sec
inet6 240e:3b7:3246:1e0:e07d:77fb:4aa5:ace/64 scope global dynamic noprefixroute
valid_lft 201116sec preferred_lft 114716sec
4: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 2c:c6:82:85:8d:fe brd ff:ff:ff:ff:ff:ff
inet 192.168.31.104/24 brd 192.168.31.255 scope global dynamic noprefixroute wlan0
valid_lft 1978sec preferred_lft 1978sec
inet6 240e:3b7:3246:1e2::b09/128 scope global dynamic noprefixroute
inet6 fdaa:0:0:30::b09/128 scope global dynamic noprefixroute
inet6 fdaa::30:ca7:7952:73cf:aa06/64 scope global noprefixroute
inet6 240e:3b7:3246:1e2:7498:9c5:1d2a:f90e/64 scope global dynamic noprefixroute
valid_lft 201117sec preferred_lft 114717sec
inet6 fe80::3dfc:b4f1:ffe4:6c50/64 scope link noprefixroute
Additional Commands:
sudo nmcli radio wifi off
: Disable WiFisudo nmcli connection delete <SSID>
: Remove a specific WiFi network
We'll use the nmcli
command-line tool to set up a WiFi hotspot.
Checking WiFi Adapter
Use the ip a
command to check the wireless network interface name.
ip a
The terminal will display output similar to the following, where wlan0
is the wireless network interface name:
Configuring a WiFi Hotspot
# Example
sudo nmcli device wifi hotspot ifname wlan0 con-name My-Hotspot ssid My-Hotspot password 12345678
This command creates a WiFi hotspot named "My-Hotspot" with password "12345678" using the wireless interface wlan0. The connection is saved as "My-Hotspot" for future management.
Parameters:
ifname
: Specifies the wireless interface for the hotspot (useip a
to find the interface name)con-name
: Specifies the connection name for managing the hotspot (start, stop, delete)ssid
: The name of the hotspot (visible to other devices)password
: The password for the hotspot
After successful setup, the terminal will display output similar to:
Disabling the WiFi Hotspot
Enabling the WiFi Hotspot
Removing the WiFi Hotspot
Testing Network Bandwidth Performance
Use the iperf
tool to test network bandwidth (throughput) performance. It's recommended to run multiple tests and calculate the average for accurate results.
Prerequisites
- Hardware Requirements
You will need two devices:
Server: A PC or server device
Client: The device to be tested (e.g., Cubie A7A)
Network Requirements
- Both server and client must be on the same local network
- They should be able to ping each other
Installing iperf
Install iperf
on both the server and client devices.
sudo apt update sudo apt install iperf
Testing Procedure
Server (PC)
Open a terminal on the server device and start the iperf server with the following command:
iperf -s
After successful startup, the terminal will display output similar to:
Client (Board)
- Upload Test
Open a terminal on the client device and enter the following command to test the upload bandwidth. Replace <server_ip>
with the actual server IP address (you can find this using the ip a
command on the server).
# 示例
iperf -c 192.168.2.186 -t 60
Parameters:
<server_ip>
: The IP address of the server<time>
: Test duration in seconds
- Download Test
Open a terminal on the client device and enter the following command to test the download bandwidth. Replace <server_ip>
# 示例
iperf -c 192.168.2.186 -t 60 -R
Parameters:
<server_ip>
: Test duration in seconds-R
: Reverse test (client receives, server sends)
