Wired Network
This guide explains how to connect to a wired network and test network bandwidth.
Wired Network
Connect the board's Gigabit Ethernet port to your router using an Ethernet cable. Once connected, the router will automatically assign an IP address to the board.
To view detailed network connection information, enter the following command in the terminal:
ip a
The terminal will display output similar to the following. The IP address assigned by the router (e.g., 192.168.2.186) will be shown in the output:
inet6 ::1/128 scope host
link/sit 0.0.0.0 brd 0.0.0.0
valid_lft 3212sec preferred_lft 3212sec
inet6 240e:3b7:3240:6e00::b09/128 scope global dynamic noprefixroute
valid_lft 3210sec preferred_lft 3210sec
inet6 240e:3b7:3240:6e00:9f8b:e83d:3c56:18e5/64 scope global dynamic noprefixroute
valid_lft 219073sec preferred_lft 132673sec
4: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether 76:13:0d:bc:43:06 brd ff:ff:ff:ff:ff:ff permaddr 2c:c6:82:85:8d:fe
Testing Network Bandwidth Performance
Use the iperf tool to test network bandwidth (throughput) performance. It's recommended to run multiple tests and calculate the average for accurate results.
Prerequisites
  • Hardware Requirements
You will need two devices:
  • Server: A PC or server device
  • Client: The device to be tested (e.g., Cubie A7A)
  • Network Requirements
    • Both server and client must be on the same local network
    • They should be able to ping each other
Installing iperf
Install iperf on both the server and client devices.
radxa@device & Linux@host$
sudo apt install iperf
Testing Procedure
Server (PC)
Open a terminal on the server device and start the iperf server with the following command:
Linux@host$
iperf -s
After successful startup, the terminal will display output similar to:
Client (Board)
  1. Upload Test
Open a terminal on the client device and enter the following command to test the upload bandwidth. Replace <server_ip> with the actual server IP address (you can find this using the ip a command on the server).
# Example
iperf -c 192.168.2.104 -t 60
Parameters:
  • <server_ip>: The IP address of the server
  • <time>: Test duration in seconds
  1. Download Test
Open a terminal on the client device and enter the following command to test the download bandwidth. Replace <server_ip> with the actual server IP address (you can find this using the ip a command on the server).
# Example
iperf -c 192.168.2.104 -t 60 -R
Parameters:
  • -R: Reverse test (client receives, server sends)
