Radxa Camera 12M 577
Radxa Dragon Q6A's onboard MIPI CSI interface can be used to connect the Radxa Camera 12M 577 for image capture.
Interface specifications
Camera interface
The Radxa Camera 12M 577 interface has the following specifications:
- Connector type: 31-pin 0.3 mm pitch SMD Horizontal FPC connector
- Connection type: Flip type, bottom contact
Board MIPI CSI interface
The Radxa Dragon Q6A MIPI CSI interface has the following specifications:
Camera FPC cable
Hardware connection
- Make sure the edges of the FPC cable are aligned with the edges of the connector, with no skew and no exposed contacts.
- Ensure the cable has no creases, is not loose, and the connector latch is fully closed.
Software enablement
Use the Rsetup tool provided by the Radxa system to enable the Radxa Camera 12M 577.
- Select option: the corresponding option will be highlighted.
- Confirm selection: press
Enter. - Cancel selection: press
ESC. - Navigate options: use
Up,Down,Left, andRightkeys. - Multi-select screen: press
Spaceto toggle options, thenEnterto confirm. When a feature is enabled, a*appears in the corresponding option box.
rsetup
- Use the arrow keys to find the [ ] Enable IMX577 camera on CAM1 option.
- Press
Spaceso it changes to [*] Enable IMX577 camera on CAM1, indicating that the feature is enabled. - Press
Enterto confirm and save the settings to enable the camera. - Reboot the system to make the configuration take effect.
If the board has multiple MIPI CSI interfaces, Rsetup may show options such as [ ] Enable IMX577 camera on CAM *. Select the option corresponding to the MIPI CSI interface you are using.
Using the camera
Use GStreamer or the libcamera qcam tool to preview or record the camera image. Run the following preview commands in the system desktop terminal.
System update
Go to Rsetup -> System -> System Update to update the system.
Using GStreamer
Install dependencies
sudo apt install -y \
gstreamer1.0-tools \
gstreamer1.0-plugins-base \
gstreamer1.0-plugins-good \
gstreamer1.0-plugins-bad
Preview the camera
gst-launch-1.0 libcamerasrc ! video/x-raw,width=1920,height=1080,framerate=30/1 ! queue ! videoconvert ! queue ! autovideosink
Record video
Software encoding (x264enc) - 1080p:
gst-launch-1.0 -e libcamerasrc \
! videoconvert ! video/x-raw,format=I420,width=1920,height=1080,framerate=30/1 \
! x264enc bitrate=8000 speed-preset=fast \
! mp4mux ! filesink location=/tmp/camera-x264.mp4
Hardware encoding H264 (Venus) - 1080p:
! videoconvert ! video/x-raw,format=NV12,width=1920,height=1080,framerate=30/1 \
! v4l2h264enc ! h264parse ! mp4mux \
! filesink location=/tmp/camera-h264.mp4
Hardware encoding H265 (Venus) - 1080p:
! v4l2h265enc ! h265parse ! mp4mux \
! filesink location=/tmp/camera-h265.mp4
Using libcamera
sudo apt install -y libcamera-tools gstreamer1.0-libcamera libcamera-ipa
Preview the camera
qcam --stream pixelformat=YUYV,width=1920,height=1080
