Radxa Camera 13M 214
Radxa Dragon Q6A's onboard MIPI CSI interface can be used to connect the Radxa Camera 13M 214 for image capture.
Interface specifications​
Camera interface​
The Radxa Camera 13M 214 interface has the following specifications:
Board MIPI CSI interface​
The Radxa Dragon Q6A MIPI CSI interface has the following specifications:
Camera FPC cable​
Hardware connection​
Notes
Software enablement​
Use the Rsetup tool provided by the Radxa system to enable the Radxa Camera 13M 214.
Rsetup usage guide
radxa@dragon-q6a$
rsetup
  1. Use the arrow keys to find the [ ] Enable Radxa Camera 13M 214 option.
  2. Press Space so it changes to [*] Enable Radxa Camera 13M 214, indicating that the feature is enabled.
If the board has multiple MIPI CSI interfaces, Rsetup may show options such as [ ] Enable Radxa Camera 13M 214 on CAM *. Select the option corresponding to the MIPI CSI interface you are using.
Using the camera​
Use GStreamer or the libcamera qcam tool to preview or record the camera image. Run the following preview commands in the system desktop terminal.
System update​
Go to Rsetup -> System -> System Update to update the system.
Using GStreamer​
Install dependencies​
radxa@dragon-q6a$
sudo apt install -y \
gstreamer1.0-tools \
gstreamer1.0-plugins-base \
gstreamer1.0-plugins-good \
gstreamer1.0-plugins-bad
Preview the camera​
radxa@dragon-q6a$
gst-launch-1.0 libcamerasrc ! video/x-raw,width=1920,height=1080,framerate=30/1 ! queue ! videoconvert ! queue ! autovideosink
Record video​
Software encoding (x264enc) - 1080p:
radxa@dragon-q6a$
gst-launch-1.0 -e libcamerasrc \
! videoconvert ! video/x-raw,format=I420,width=1920,height=1080,framerate=30/1 \
! x264enc bitrate=8000 speed-preset=fast \
! mp4mux ! filesink location=/tmp/camera-x264.mp4
Hardware encoding H264 (Venus) - 1080p:
radxa@dragon-q6a$
! videoconvert ! video/x-raw,format=NV12,width=1920,height=1080,framerate=30/1 \
! v4l2h264enc ! h264parse ! mp4mux \
! filesink location=/tmp/camera-h264.mp4
Hardware encoding H265 (Venus) - 1080p:
radxa@dragon-q6a$
! v4l2h265enc ! h265parse ! mp4mux \
! filesink location=/tmp/camera-h265.mp4
Using libcamera​
radxa@dragon-q6a$
sudo apt install -y libcamera-tools gstreamer1.0-libcamera libcamera-ipa
Preview the camera​
radxa@dragon-q6a$
qcam --stream pixelformat=YUYV,width=1920,height=1080
