Radxa Camera 8M 219
Radxa Dragon Q6A's onboard MIPI CSI interface can be used to connect the Radxa Camera 8M 219 for image capture.
Interface specifications​
Camera interface​
The Radxa Camera 8M 219 interface has the following specifications:
  • Connector type: 15-pin 1.0 mm pitch SMD Horizontal FPC connector
Board MIPI CSI interface​
The Radxa Dragon Q6A MIPI CSI interface has the following specifications:
Camera FPC cable​
Use a 15-Pin 1.0 mm pitch to 15-Pin 1.0mm pitch opposite sides FPC cable.
Hardware connection​
Insert the 15-pin metal contacts of the FPC cable into the camera connector, and insert the 15-Pin metal contacts of the FPC cable into the board MIPI CSI connector.
Notes
Software enablement​
Use the Rsetup tool provided by the Radxa system to enable the Radxa Camera 8M 219.
Rsetup usage guide
radxa@dragon-q6a$
rsetup
  1. Use the arrow keys to find the [ ] Enable Radxa Camera 8M 219 option.
  2. Press Space so it changes to [*] Enable Radxa Camera 8M 219, indicating that the feature is enabled.
If the board has multiple MIPI CSI interfaces, Rsetup may show options such as [ ] Enable Radxa Camera 8M 219 on CAM *. Select the option corresponding to the MIPI CSI interface you are using.
Using the camera​
Use GStreamer or the libcamera qcam tool to preview or record the camera image. Run the following preview commands in the system desktop terminal.
System update​
Go to Rsetup -> System -> System Update to update the system.
Using GStreamer​
Install dependencies​
radxa@dragon-q6a$
sudo apt install -y \
gstreamer1.0-tools \
gstreamer1.0-plugins-base \
gstreamer1.0-plugins-good \
gstreamer1.0-plugins-bad
Preview the camera​
radxa@dragon-q6a$
gst-launch-1.0 libcamerasrc ! video/x-raw,width=1920,height=1080,framerate=30/1 ! queue ! videoconvert ! queue ! autovideosink
Record video​
Software encoding (x264enc) - 1080p:
radxa@dragon-q6a$
gst-launch-1.0 -e libcamerasrc \
! videoconvert ! video/x-raw,format=I420,width=1920,height=1080,framerate=30/1 \
! x264enc bitrate=8000 speed-preset=fast \
! mp4mux ! filesink location=/tmp/camera-x264.mp4
Hardware encoding H264 (Venus) - 1080p:
radxa@dragon-q6a$
! videoconvert ! video/x-raw,format=NV12,width=1920,height=1080,framerate=30/1 \
! v4l2h264enc ! h264parse ! mp4mux \
! filesink location=/tmp/camera-h264.mp4
Hardware encoding H265 (Venus) - 1080p:
radxa@dragon-q6a$
! v4l2h265enc ! h265parse ! mp4mux \
! filesink location=/tmp/camera-h265.mp4
Using libcamera​
radxa@dragon-q6a$
sudo apt install -y libcamera-tools gstreamer1.0-libcamera libcamera-ipa
Preview the camera​
radxa@dragon-q6a$
qcam --stream pixelformat=YUYV,width=1920,height=1080
Troubleshooting​
Check if the camera is recognized​
Use the following command to check if the camera is recognized by the system:
radxa@dragon-q6a$
sudo dmesg | grep imx
If the terminal outputs the following information, the camera is recognized properly:
[    5.949209] imx219 18-0010: supply VANA not found, using dummy regulator
[ 5.951349] imx219 18-0010: supply VDIG not found, using dummy regulator
[ 5.951506] imx219 18-0010: supply VDDL not found, using dummy regulator
If the terminal outputs the following information, the camera is not recognized by the system, and you need to check if the camera cable is properly installed:
[ 5.958515] imx219 18-0010: Error reading reg 0x0000: -6
[ 5.958522] imx219 18-0010: error -ENXIO: failed to read chip id 219
