Enable NPU on Board
When using system image version R2 or higher, the NPU runtime environment is pre-installed and no additional installation is required.
NPU Environment Configuration Checklist
  • fastrpc
  • /dev/fastrpc-adsp
  • /dev/fastrpc-cdsp
  • /dev/fastrpc-cdsp-secure
  • /usr/lib/dsp libraries
Install using radxa apt source
Prerequisite
These packages depend on the Radxa APT source included in the official RadxaOS images. Before following the steps below, make sure the device is running the official RadxaOS image for the target board. If you are using a third-party Ubuntu/Debian image or have replaced the package sources, fastrpc / fastrpc-test may not be available.
sudo apt install fastrpc libcdsprpc1
Verify fastrpc status
sudo apt install fastrpc-test
fastrpc_test -a v68
rock@radxa-dragon-q6a:~$ fastrpc_test -a v68
Demonstrating FARF run-time logging
hap_example function PASSED
Please look at the mini-dm logs or the adb logcat logs for DSP output
Demonstrating HAP_mem.h APIs
Demonstrating HAP_perf.h APIs
[PASS] libhap_example.so
Test PASSED
[PASS] libmultithreading.so
Allocate 4000 bytes from ION heap
Creating sequence of numbers from 0 to 999
Compute sum on domain 3
Call calculator_sum on the DSP
Sum = 499500
Call calculator_max on the DSP
Max value = 999
[PASS] libcalculator.so
Test Summary:
Total tests run: 3
Passed: 3
Failed: 0
Skipped: 0
RESULT: All applicable tests PASSED
