Real ESRGAN Example
This document explains how to run Real-ESRGAN-x4plus on Radxa Dragon Q6A using the QAI AppBuilder Python library. Image Super-Resolution Model.
Install QAI AppBuilder
Run the Example
Install Dependencies
pip3 install requests tqdm qai-hub py3_wget opencv-python torch
Run the Script
  • Navigate to the example directory
    cd ai-engine-direct-helper/samples/linux/python
  • Prepare the input image. The following image is used as an example:
    Input Image
  • Execute the inference
    python3 real_esrgan_x4plus/real_esrgan_x4plus.py
    (.venv) ubuntu@ubuntu:~/git_clone/ai-engine-direct-helper/samples/linux/python$ python3 real_esrgan_x4plus/real_esrgan_x4plus.py
    Current file directory: /home/ubuntu/git_clone/ai-engine-direct-helper/samples/linux/python/real_esrgan_x4plus
    1123.1ms [WARNING] Time: model_destroy realesrgan 9.12
  • Output Results
    Output Image
