OpenCV Example
This document demonstrates OpenCV image preview, camera access, and computer vision examples.
Image Preview
Learn how to read and display images and camera feeds.
Image Preview
Read and display an image.
Steps to run the example:
  1. Create a new file preview_image.py
  2. Copy the code into preview_image.py
  3. Run the example using python3 preview_image.py
  4. Click on the preview window and press 'q' to exit the program
preview_image.py
#!/usr/bin/env python3
# -_- encoding: utf-8 -_-
import cv2
# Read the image
image_path = './radxa_logo.png' # Replace with your image path
image = cv2.imread(image_path)
# Check if the image is loaded successfully
if image is None:
print("Failed to load image. Please check the file path.")
else: # Display the image in a window
while True:
cv2.imshow('Preview', image) # Wait for 'q' key to quit
break
cv2.destroyAllWindows()
Preview effect:
Camera Preview
Access and display the camera feed in real-time.
  1. Create a new file preview_camera.py
  2. Copy the code into preview_camera.py
  3. Run the example using python3 preview_camera.py
In the code, cv2.VideoCapture(0) opens the default camera at /dev/video0. If you have multiple cameras or your camera device file is different, please modify this value accordingly.
preview_camera.py
import cv2
# Open the camera
video_capture = cv2.VideoCapture(0)
while True:
# Read a frame from the camera
ret, frame = video_capture.read()
# Check if the frame is read successfully
if not ret:
print("Failed to read frame. Please check the camera connection.")
break
# Display the frame in a window
cv2.imshow('Preview', frame)
break
# Release the camera and close the window
video_capture.release()
Preview effect:
Harris Corner Detection
Harris Corner Detection is a classic algorithm for detecting corners in images, which are important features in computer vision.
Image-based Detection
Read an image and perform Harris corner detection.
  1. Create a new file harris_image.py
  2. Copy the code into harris_image.py
  3. Run the example using python3 harris_image.py
harris_image.py
import cv2
import numpy as np
# Harris corner detection parameters
block_size = 2
ksize = 3
k = 0.04
threshold = 0.01
# Read the image
if image is None:
else:
# Convert to grayscale
gray = cv2.cvtColor(image, cv2.COLOR_BGR2GRAY)
gray = np.float32(gray)
# Apply Harris corner detection
dst = cv2.cornerHarris(gray, block_size, ksize, k)
# Dilate corner points for better visualization
dst = cv2.dilate(dst, None)
# Mark corners in red
image[dst > threshold * dst.max()] = [0, 0, 255]
# Display the result
while True:
cv2.imshow('Harris Corners', image)
break
Preview effect:
Real-time Detection
Access camera feed and perform Harris corner detection in real-time.
  1. Create a new file harris_camera.py
  2. Copy the code into harris_camera.py
  3. Run the example using python3 harris_camera.py
harris_camera.py
import cv2
import numpy as np
block_size = 2
ksize = 3
k = 0.04
threshold = 0.01
# Initialize the camera
cap = cv2.VideoCapture(0)
# Check if the camera is opened successfully
if not cap.isOpened():
print("Error: Could not open camera.")
exit()
while True: # Capture frame-by-frame
ret, frame = cap.read()
# If frame is read correctly, ret is True
if not ret:
print("Error: Failed to capture frame.")
break
# Create a copy of the frame for processing
display_frame = frame.copy()
gray = cv2.cvtColor(frame, cv2.COLOR_BGR2GRAY)
display_frame[dst > threshold * dst.max()] = [0, 0, 255]
# Display the resulting frame
cv2.imshow('Harris Corners - Camera', display_frame)
# Press 'q' to exit
break
# When everything done, release the capture and close windows
cap.release()
Preview effect:
Shi-Tomasi Corner Detection
Shi-Tomasi Corner Detection is an improved algorithm for corner detection in images, based on Harris Corner Detection, used to detect corners in images.
Read an image and perform Shi-Tomasi corner detection.
  1. Create a new file shi_tomasi_image.py
  2. Copy the code into shi_tomasi_image.py
  3. Run the example using python3 shi_tomasi_image.py
shi_tomasi_image.py
import cv2
import numpy as np
# Shi-Tomasi corner detection parameters
max_corners = 100
quality_level = 0.01
min_distance = 10
# Read the image
if image is None:
else: # Create a copy of the image for display
display_image = image.copy()
# Detect corners using Shi-Tomasi
corners = cv2.goodFeaturesToTrack(gray, max_corners, quality_level, min_distance)
# Draw circles around detected corners
if corners is not None:
corners = np.int0(corners)
for corner in corners:
x, y = corner.ravel()
cv2.circle(display_image, (x, y), 5, (0, 255, 0), -1) # Green circles
while True:
cv2.imshow('Shi-Tomasi Corners', display_image)
break
Preview effect:
Real-time Detection
Access camera feed and perform Shi-Tomasi corner detection in real-time.
  1. Create a new file shi_tomasi_camera.py
  2. Copy the code into shi_tomasi_camera.py
  3. Run the example using python3 shi_tomasi_camera.py
import cv2
import numpy as np
max_corners = 100
min_distance = 10
exit()
if not ret:
break
# Create a copy of the frame for display
cv2.circle(display_frame, (x, y), 5, (0, 255, 0), -1) # Green circles
cv2.imshow('Shi-Tomasi Corners - Camera', display_frame)
# Press 'q' to exit
break
cap.release()
Preview effect:
ORB Feature Detection
ORB (Oriented FAST and Rotated BRIEF) is an efficient feature detection and description method. It combines the FAST keypoint detector with the BRIEF descriptor, with improvements that enhance performance, especially in computational efficiency and rotation invariance.
Read an image and perform ORB feature detection.
  1. Create a new file orb_image.py
  2. Copy the code into orb_image.py
  3. Run the example using python3 orb_image.py
orb_image.py
import cv2
import numpy as np
# Read the image
if image is None:
# Initialize ORB detector
orb = cv2.ORB_create(nfeatures=500)
# Detect keypoints and compute descriptors
keypoints, descriptors = orb.detectAndCompute(gray, None)
# Draw keypoints on the image
display_image = cv2.drawKeypoints(image, keypoints, None, color=(0, 255, 0),
flags=cv2.DRAW_MATCHES_FLAGS_DEFAULT)
while True:
cv2.imshow('ORB Features', display_image)
break
Preview effect:
Real-time Detection
Access camera feed and perform ORB feature detection in real-time.
  1. Create a new file orb_camera.py
  2. Copy the code into orb_camera.py
  3. Run the example using python3 orb_camera.py
orb_camera.py
import cv2
import numpy as np
exit()
if not ret:
break
# Draw keypoints on the frame
display_frame = cv2.drawKeypoints(frame, keypoints, None,
color=(0, 255, 0),
# Display the number of keypoints
cv2.putText(display_frame, f'Keypoints: {len(keypoints)}', (10, 30),
cv2.FONT_HERSHEY_SIMPLEX, 1, (0, 0, 255), 2)
cv2.imshow('ORB Features - Camera', display_frame)
# Press 'q' to exit
break
cap.release()
Preview effect:
Face Recognition
Based on Haar Cascade classifier, this function implements face detection using a pre-trained Haar Cascade classifier, which quickly locates the face region in an image through machine learning training.
Read an image and perform face recognition.
  1. Create a new file face_recognition_image.py
  2. Copy the code into face_recognition_image.py
  3. Run the example using python3 face_recognition_image.py
import cv2
import os
# Load the pre-trained Haar Cascade classifier for face detection
face_cascade = cv2.CascadeClassifier(cv2.data.haarcascades + 'haarcascade_frontalface_default.xml')
# Read the image
image_path = 'people.png' # Replace with your image path
if image is None:
print(f"Error: Could not read image at {image_path}")
exit()
# Convert to grayscale (face detection works on grayscale images)
# Detect faces in the image
faces = face_cascade.detectMultiScale(
gray,
scaleFactor=1.1, # Scale factor for image pyramid
minNeighbors=5, # How many neighbors each candidate rectangle should have
minSize=(30, 30) # Minimum possible object size
# Draw rectangles around the faces
for (x, y, w, h) in faces:
cv2.rectangle(image, (x, y), (x+w, y+h), (0, 255, 0), 2)
# Display the number of faces detected
print(f"Number of faces detected: {len(faces)}")
while True:
cv2.imshow('Face Detection', image) # Wait for 'q' key to quit
break
Preview effect:
Real-time Detection
Access camera feed and perform face recognition in real-time.
  1. Create a new file face_recognition_camera.py
  2. Copy the code into face_recognition_camera.py
  3. Run the example using python3 face_recognition_camera.py
import cv2
exit()
if not ret:
break
# Detect faces in the frame
gray,
cv2.rectangle(frame, (x, y), (x+w, y+h), (0, 255, 0), 2)
cv2.putText(frame, f'Faces: {len(faces)}', (10, 30),
cv2.imshow('Face Detection - Camera', frame)
# Press 'q' to exit
break
cap.release()
Preview effect:
