ROS1 Installation
Main introduction to setting up the ROS1 Noetic version environment.
  • It is recommended to perform the following operations based on VNC / NoMachine remote desktop or by connecting a display.
  • The ROS environment is built in a Docker container. It is recommended to install and learn how to use Docker first.
  • Ubuntu is the officially preferred and primarily supported distribution for ROS. We will build the ROS environment based on Docker's Ubuntu image.
Pull Docker Image​
Use the docker pull command to pull the Ubuntu 20.04 Docker image.
radxa@dragon-q6a$
docker pull ubuntu:20.04
Write Docker Script​
Use a script to start the Ubuntu 20.04 Docker container.
You need to write a startup script ros_noetic.sh:
radxa@dragon-q6a$
vi ros_noetic.sh
Add the following content to the ros_noetic.sh script:
#!/bin/bash
xhost +
docker run -it \
--net=host \
--env="DISPLAY" \
--env="QT_X11_NO_MITSHM=1" \
--name ros1 \
ubuntu:20.04 /bin/bash
Parameter description:
  • xhost +: Allow Docker container to access X11 server
  • -it: Run container in interactive mode
  • --net=host: Use host's network stack
  • --env="DISPLAY": Set environment variable for displaying X11 graphical interface
  • --env="QT_X11_NO_MITSHM=1": Set environment variable for Qt application display
  • -v /tmp/.X11-unix:/tmp/.X11-unix: Mount X11 Unix domain socket for displaying X11 graphical interface
  • --name ros1: Specify name for the container
  • ubuntu:20.04: Use Ubuntu 20.04 image
  • /bin/bash: Start Bash shell inside the container
Start Docker Container​
Use the bash command to start the script.
radxa@dragon-q6a$
bash ros_noetic.sh
Install Noetic​
Check Encoding Environment​
Ensure that the environment for installing Noetic supports UTF-8 encoding.
radxa@dragon-q6a$
locale
If the system encoding format is UTF-8, you can see similar information output in the terminal:
LANG=en_US.UTF-8
LANGUAGE=
LC_CTYPE="en_US.UTF-8"
LC_NUMERIC="en_US.UTF-8"
LC_TIME="en_US.UTF-8"
LC_COLLATE="en_US.UTF-8"
LC_MONETARY="en_US.UTF-8"
LC_MESSAGES="en_US.UTF-8"
LC_PAPER="en_US.UTF-8"
LC_NAME="en_US.UTF-8"
LC_ADDRESS="en_US.UTF-8"
LC_TELEPHONE="en_US.UTF-8"
LC_MEASUREMENT="en_US.UTF-8"
LC_ALL=
If the terminal output information is not UTF-8 encoded, you can enter the following commands in the terminal to install and modify the encoding environment:
radxa@dragon-q6a$
locale-gen en_US en_US.UTF-8
source ~/.bashrc
Set Software Sources and Keys​
Ensure the system is in the latest environment, then add Tsinghua software sources and keys.
radxa@dragon-q6a$
apt update && apt upgrade
apt install lsb-core
sh -c '. /etc/lsb-release && echo "deb http://mirrors.tuna.tsinghua.edu.cn/ros/ubuntu/ `lsb_release -cs` main" > /etc/apt/sources.list.d/ros-latest.list'
apt-key adv --keyserver 'hkp://keyserver.ubuntu.com:80' --recv-key C1CF6E31E6BADE8868B172B4F42ED6FBAB17C654
Install Noetic​
Use the following command to install Noetic full desktop version.
radxa@dragon-q6a$
apt install ros-noetic-desktop-full -y
Install Dependencies​
Use the following command to install Noetic dependency packages.
radxa@dragon-q6a$
apt install python3-rosdep python3-rosinstall python3-rosinstall-generator python3-wstool build-essential -y
Initialize rosdep​
Use the following command to initialize rosdep.
radxa@dragon-q6a$
rosdep init
rosdep update
If rosdep init shows the error ERROR: cannot download default sources list from: https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/sources.list.d/20-default.list Website may be down., visit https://www.ipaddress.com/ to search for the raw.githubusercontent.com domain, and add the resulting IP address to the /etc/hosts file.
radxa@dragon-q6a$
vi /etc/hosts
Add the following content:
Then re-run the rosdep initialization command.
Set Environment Variables​
Use the following command to set environment variables:
radxa@dragon-q6a$
echo "source /opt/ros/noetic/setup.bash" >> ~/.bashrc
source ~/.bashrc
Verify ROS Environment​
Enter the following command in the terminal to verify whether the ROS environment was installed successfully.
radxa@dragon-q6a
roscore
If the installation is successful, you will see similar information output:
... logging to /root/.ros/log/a9473172-5731-11f0-9a87-5acb6b3cedae/roslaunch-rock-4d-spi-27211.log
Checking log directory for disk usage. This may take a while.
Press Ctrl-C to interrupt
Done checking log file disk usage. Usage is <1GB.
started roslaunch server http://rock-4d-spi:34861/
ros_comm version 1.17.4
# SUMMARY
PARAMETERS
- /rosdistro: noetic
- /rosversion: 1.17.4
NODES
auto-starting new master
process[master]: started with pid [27219]
ROS_MASTER_URI=http://rock-4d-spi:11311/
setting /run_id to a9473172-5731-11f0-9a87-5acb6b3cedae
process[rosout-1]: started with pid [27229]
started core service [/rosout]
You can use Ctrl + C to stop roscore.
Save Docker Image​
Currently, all our modifications are based on the Ubuntu 20.04 Docker container. We need to save this modified container as an image for direct use next time.
Note: If not saved as an image, you will need to reinstall the ROS environment when starting the container next time.
radxa@dragon-q6a$
docker commit ros1 ros_noetic:1.0
  • ros1: The previously specified container name
  • ros_noetic:1.0: The name of the saved image
Wait for the commit to complete. After completion, you will see similar information output:
sha256:43b559a4d879c83477764730e0af90e8904e8fb8aeeeb9b653967e665bb7a7ca
Modify Startup Script​
Modify the startup image in the startup script ros_noetic.sh to the image name just saved:
#!/bin/bash
xhost +
docker run -it \
--net=host \
--env="DISPLAY" \
ros_noetic:1.0 /bin/bash
