ROS2 Installation
Main introduction to setting up the ROS2 Humble version environment.
  • It is recommended to perform the following operations based on VNC / NoMachine remote desktop or by connecting a display.
  • The ROS2 environment is built in a Docker container. It is recommended to install and learn how to use Docker first.
  • Ubuntu is the officially preferred and primarily supported distribution for ROS2. We will build the ROS2 environment based on Docker's Ubuntu image.
Pull Docker Image​
Use the docker pull command to pull the Ubuntu 22.04 Docker image.
radxa@dragon-q6a$
docker pull ubuntu:22.04
Write Docker Script​
Use a script to start the Ubuntu 22.04 Docker container.
You need to write a startup script ros_humble.sh:
radxa@dragon-q6a$
vi ros_humble.sh
Add the following content to the script:
#!/bin/bash
xhost +
docker run -it \
--net=host \
--env="DISPLAY" \
--env="QT_X11_NO_MITSHM=1" \
--name ros2 \
ubuntu:22.04 /bin/bash
Parameter description:
  • xhost +: Allow Docker container to access X11 server
  • -it: Run container in interactive mode
  • --net=host: Use host's network stack
  • --env="DISPLAY": Set environment variable for displaying X11 graphical interface
  • --env="QT_X11_NO_MITSHM=1": Set environment variable for Qt application display
  • -v /tmp/.X11-unix:/tmp/.X11-unix: Mount X11 Unix domain socket for displaying X11 graphical interface
  • --name ros2: Specify name for the container
  • ubuntu:22.04: Use Ubuntu 22.04 image
  • /bin/bash: Start Bash shell inside the container
Start Docker Container​
Use the bash command to start the script.
radxa@dragon-q6a$
bash ros_humble.sh
Install Humble​
Check Encoding Environment​
Ensure that the environment for installing Humble supports UTF-8 encoding.
radxa@dragon-q6a$
locale
If the system encoding format is UTF-8, you can see similar information output in the terminal:
LANG=en_US.UTF-8
LANGUAGE=
LC_CTYPE="en_US.UTF-8"
LC_NUMERIC="en_US.UTF-8"
LC_TIME="en_US.UTF-8"
LC_COLLATE="en_US.UTF-8"
LC_MONETARY="en_US.UTF-8"
LC_MESSAGES="en_US.UTF-8"
LC_PAPER="en_US.UTF-8"
LC_NAME="en_US.UTF-8"
LC_ADDRESS="en_US.UTF-8"
LC_TELEPHONE="en_US.UTF-8"
LC_MEASUREMENT="en_US.UTF-8"
LC_ALL=
If the terminal output information is not UTF-8 encoded, you can enter the following commands in the terminal to install and modify the encoding environment:
radxa@dragon-q6a$
locale-gen en_US en_US.UTF-8
source ~/.bashrc
Set Software Sources and Keys​
Ensure the system is in the latest environment, then enable the Ubuntu Universe repository and add ROS2 keys.
radxa@dragon-q6a$
apt-cache policy | grep universe
apt install software-properties-common curl -y
add-apt-repository universe
curl -sSL https://raw.githubusercontent.com/ros/rosdistro/master/ros.key -o /usr/share/keyrings/ros-archive-keyring.gpg
If you encounter the error: curl: (7) Failed to connect to raw.githubusercontent.com port 443 after 43 ms: Connection refused Solution: Visit https://www.ipaddress.com/ to search for the raw.githubusercontent.com domain, and add the resulting IP address to the /etc/hosts file.
radxa@dragon-q6a$
vi /etc/hosts
Add the following content:
Then re-run the command to add ROS2 keys.
radxa@dragon-q6a$
Add the repository to the sources list:
radxa@dragon-q6a$
echo "deb [arch=$(dpkg --print-architecture) signed-by=/usr/share/keyrings/ros-archive-keyring.gpg] http://packages.ros.org/ros2/ubuntu $(. /etc/os-release && echo $UBUNTU_CODENAME) main" | tee /etc/apt/sources.list.d/ros2.list > /dev/null
Install Humble​
Use the following command to install Humble full desktop version.
radxa@dragon-q6a$
apt update && apt upgrade
apt install ros-humble-desktop-full -y
Install ROS2 Development Tools​
Use the following command to install ROS2 development tools.
radxa@dragon-q6a$
apt install ros-dev-tools -y
Set Environment Variables​
Use the following command to set environment variables:
radxa@dragon-q6a$
echo "source /opt/ros/humble/setup.bash" >> ~/.bashrc
source ~/.bashrc
Save Docker Image​
Currently, all our modifications are based on the Ubuntu 22.04 Docker container. We need to save this modified container as an image for direct use next time.
Note: If not saved as an image, you will need to reinstall the ROS2 environment when starting the container next time.
radxa@dragon-q6a$
docker commit ros2 ros_humble:1.0
  • ros2: The previously specified container name
  • ros_humble:1.0: The name of the saved image
Wait for the commit to complete. After completion, you will see similar information output:
sha256:32288d439ffab73505d0754d4c43d8aad83210441b41553118e81ff6ab2887af
Modify Startup Script​
Modify the startup image in the startup script ros_humble.sh to the image name just saved:
ros_humble.sh
#!/bin/bash
xhost +
docker run -it \
--net=host \
--env="DISPLAY" \
ros_humble:1.0 /bin/bash
