Installing System Using Card Reader
This guide explains how to use the Radxa eMMC/UFS module reader with an eMMC module to install the system onto the eMMC module.
warning
Installing the system will format the eMMC module. Please back up any important data in advance!
Hardware Requirements​
You need to prepare the following hardware devices in advance:
  • eMMC module
  • Radxa eMMC/UFS Module Reader
Hardware Connection​
Insert the eMMC module into the Radxa eMMC/UFS Module Reader, then connect the reader to your computer.
caution
eMMC Module Installation Steps:
  1. Ensure the notch on the eMMC module aligns with the interface direction of the module reader
  2. Make sure the slot interface at the bottom of the eMMC module aligns with the module reader's interface
  3. Gently press one end of the eMMC module until you hear a "click" sound, indicating successful installation. Use the same method to press the other end to ensure the eMMC module is properly installed.
System Installation​
Download System Image​
Use your PC to access the Resource Download page and download the system image file to your local machine.
Image Note
Install System Image​
You can use Balena Etcher software to install the system image onto the eMMC module.
Balena Etcher
For installation and usage instructions of Balena Etcher, you can refer to the Etcher Usage tutorial.
Select System Image​
Click the Flash from file option and select the system image file you downloaded and extracted earlier.
Select Storage Device​
Click the Select target option and choose the eMMC module device.
Start Flashing​
Click the Flash! option to begin writing the system image to the eMMC module.
Waiting for system installation to complete
Waiting for system verification to complete
Booting the System​
After completing the system installation, install the eMMC module into the eMMC module interface of the Dragon Q6A, then power on the Dragon Q6A using a 12V Type-C power adapter to boot the system.
① : Install the eMMC module
② : Connect the monitor to the motherboard using an HDMI cable
③ : Power the Dragon Q6A using a 12V Type-C power adapter
When the system boots normally, the power indicator will light up green, and the status indicator will flash blue.
Logging into the System​
When you start the system for the first time, you need to log in using the default username and password.
ItemContent
Usernameradxa
Passwordradxa
Using the System​
After successfully booting the system, you can start using the Radxa OS on your Dragon Q6A. For basic usage of the Radxa OS, please refer to the Using the System tutorial.
