Flash System Image to microSD Card
This guide explains how to flash a system image to a microSD card using a USB Type-A to Type-A cable.
  1. Insert the microSD card into the board's microSD card slot
  2. Put the board into EDL mode and connect it to your computer using a USB Type-A to Type-A cable --> Refer to the Entering EDL Mode guide
  3. Set up the EDL tool environment --> Refer to the Using EDL Tool guide
Download System Image​
You need to visit the Downloads page to download the latest system image.
Image Note
Flash System via USB​
You need to copy the extracted system image file to the SPI boot firmware's \flat_build\spinor\dragon-q6a\ directory, then open a terminal in that folder and run the following command to flash the system image:
radxa@dragon-q6a$
# Method 1: Flash using rawprogram XML files (recommended)
# Method 2: Write raw sectors directly
Parameter Description:
  • <path-to-loader>: Path to the bootloader, replace with the actual bootloader path.
  • <storage-type>: Storage type, replace with the actual storage type.
  • <start-sector>: Starting sector, replace with the actual starting sector.
  • <path-to-image-file>: Path to the system image file, replace with the actual system image file path.
Example:
edl-ng --loader prog_firehose_ddr.elf --memory Sdcc --slot 1 write-sector 0 radxa-dragon-q6a_noble_gnome_r2.output_512.img
How to tell whether flashing succeeded​
After you run edl-ng ... rawprogram ..., the terminal will show the write progress for each partition. If flashing succeeds, you should see output similar to:
If you see output like this and it shows command finished successfully at the end, the image write is complete.
Note
If you see Error: Image file ... not found but it still shows command finished successfully at the end, you can ignore this error - it's just because some optional partition files don't exist.
Common failure signs​
If the terminal doesn't show command finished successfully, or instead prints errors such as Error: / Operation Error: / IO Error: / Platform Error:, then the flash did not complete successfully. Common examples include:
An unexpected error occurred in 'write-sector': <specific error message>
If flashing fails, first check:
  1. Whether the board has actually entered EDL mode.
  2. Whether the prog_firehose_ddr.elf path is correct.
  3. Whether the storage type matches the target media (for example ufs, Sdcc --slot 0, or nvme).
  4. Whether the image file has been fully extracted and the path is correct.
  5. Whether the USB data cable and the board-to-host connection are stable.
