Ethernet Interface (Supports PoE)
The Dragon Q6A's onboard gigabit Ethernet interface supports PoE functionality, which requires the use of a PoE HAT.
Hardware Connection​
  • Network Connection Only
Connect the Gigabit Ethernet interface on the motherboard to the Gigabit Ethernet interface on the router using an Ethernet cable.
Under normal circumstances, the Gigabit Ethernet interface indicator light on the Radxa Dragon Q6A will flash, indicating a normal network connection.
  • Power Over Ethernet (PoE)
Power and data transmission are achieved over a single cable, requiring the use of a PoE HAT.
After installing the PoE HAT on the Radxa Dragon Q6A, connect the Gigabit Ethernet port of the Radxa Dragon Q6A to the Gigabit Ethernet port of the Ethernet PoE switch using an Ethernet cable.
Without a power adapter, the power indicator light on the Radxa Dragon Q6A will be lit, indicating normal power supply; the Gigabit Ethernet port indicator light will flash, indicating a normal network connection.
Network Information​
We can use the ip a command to view detailed network information.
ip a
Terminal output example: where 192.168.4.165 is the Gigabit Ethernet interface IP address.
inet6 ::1/128 scope host noprefixroute
link/sit 0.0.0.0 brd 0.0.0.0
3: enp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 00:e0:4c:68:00:03 brd ff:ff:ff:ff:ff:ff
inet 192.168.4.165/24 brd 192.168.4.255 scope global dynamic noprefixroute enp1s0
valid_lft 43182sec preferred_lft 43182sec
inet6 fe80::9222:1ab7:a6a6:898/64 scope link noprefixroute
4: wlx68249956ac87: <NO-CARRIER,BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state DORMANT group default qlen 1000
link/ether 68:24:99:56:ac:87 brd ff:ff:ff:ff:ff:ff
Interface Pin Definitions​
Please refer to the hardware schematic diagram on the Resource Summary Download page.
