Hardware Information
System Block Diagram​
Interface Description​
No.DescriptionNo.DescriptionNo.Description
1Qualcomm QCS6490240-Pin GPIO Header3M.2 M Key slot
4WiFi 6 / BT 5.45Antenna connector6Power button
7User LED8Power LED9Type-C power input
10Power input header11MIPI CSI (4 Lane)12microSD card slot
13MIPI DSI (4 Lane)14PoE header15Gigabit Ethernet
16QSPI Nor Flash17USB ports
USB 2.0 Type-A (upper) / USB 3.1 OTG Type-A (lower)
18LPDDR5 memory
192x USB 2.0 Type-A ports20EDL button21Headphone jack
22Standard HDMI23eMMC & UFS module connector24RTC battery connector
252x MIPI CSI (2 Lane)
Power Input Header Pinout​
No. 10 is the 12V external power input interface, a 3-pin header with the following pin functions:
PinDefinition
112V
2GND
3PWR
External power supply​
Connect the positive and negative terminals of the 12V power supply to the 12V and GND pins on the Dragon Q6A to power it.
danger
Please do not connect the power supply incorrectly or in reverse, as improper operation may cause hardware damage.
External power button​
By default, when the Dragon Q6A is powered off, briefly short the PWR and GND pins to start it; when the Dragon Q6A is powered on, briefly short the PWR and GND pins to bring up the shutdown menu.
