MIPI DSI Interface
The Dragon Q6A has one 4-lane MIPI DSI interface on board for connecting MIPI displays.
Supported Displays
| Model | Size (in inches) | Resolution |
| Radxa Display 10 FHD | 10.1 | 1200*1920 |
| Radxa Display 8 HD | 8 | 800*1280 |
Only the Radxa official displays listed above are supported. Third-party displays (e.g., the Raspberry Pi 7" touchscreen) are not officially adapted: even if a physical connection is made with an adapter cable, display and touch functionality depend on whether the system image includes a matching panel driver / device tree, and compatibility cannot be guaranteed.
The table above lists the compatible display models, but not every system image includes the panel configuration for every model:
- Radxa OS (Linux): both Display 10 FHD and Display 8 HD in the table above work normally.
- Android: the current Dragon Q6A Android images do not include the panel configuration for Display 10 FHD, so Display 10 FHD is not currently supported under Android (it may show a black screen after connection).
The displays actually supported by each system image are subject to the release notes of that image.
Hardware Connection
Connect the MIPI display to the Dragon Q6A's MIPI DSI interface (39-Pin / 0.3mm pitch FPC connector) via an FPC ribbon cable.
Refer to the Hardware Information tutorial to locate the corresponding hardware interface.
Interface Pin Definition
Refer to the hardware schematic diagram on the Resource Summary Download page.
