eMMC/UFS Module Combination Interface
The Radxa Dragon Q6A features an onboard eMMC/UFS module combination interface, supporting both eMMC and UFS modules.
danger
Do not use untested third-party UFS or eMMC modules. Some third-party modules may short the SBC and cause permanent hardware damage, and such damage is not covered by warranty.
Hardware Connection​
Install the eMMC module or UFS module into the eMMC/UFS module combination interface on the Radxa Dragon Q6A.
eMMC/UFS Module Installation Steps:
  1. Ensure that the notched corners of the eMMC/UFS module align with the notched corners of the eMMC/UFS module combo interface on the motherboard.
  2. Ensure that the bottom slot interface of the eMMC/UFS module aligns with the eMMC/UFS module combo interface on the motherboard.
  3. Gently press the interface at one end of the eMMC/UFS module. If you hear a click, the installation is successful. Use the same method to press the interface at the other end to ensure that the eMMC/UFS module is installed successfully.
Interface Location
You can refer to the Hardware Information tutorial to find the corresponding hardware interface location.
Usage Guide​
The eMMC module or UFS module can be used as a system boot medium or as expanded storage space.
For system installation, refer to the following tutorials:
UFS Performance Reference​
The following table shows measured read/write performance of different UFS modules on the Dragon Q6A, tested using the dd command. Data is for reference only.
Product NameUFS Chip Brand/ModelCapacityRead SpeedWrite SpeedTest Environment
Radxa UFS ModuleSamsung KLUDG4UHDC-B0E1 (UFS 3.1)128GB1703 MB/s388 MB/sRadxa OS (Linux)
Radxa UFS ModuleKioxia THGJFGT1E45BAILB256GB1811 MB/s557 MB/sRadxa OS (Linux)
Note: Actual read/write speeds may vary depending on the UFS module brand, capacity, firmware version, and test environment. The above data are measured reference values.
Interface Pin Definition​
Refer to the hardware schematic diagram on the Resource Summary Download page.
