Burn SPI boot firmware
Firmware Notes
The Dragon Q6A comes with SPI boot firmware pre-installed. Under normal circumstances, there is no need to re-flash the boot firmware. However, if the system fails to boot properly, you can try re-flashing the SPI boot firmware.
The primary function of the SPI boot firmware (BootROM + bootloader) is to initialize hardware in stages (CPU → memory → storage) and ultimately load the operating system kernel from the storage device. :: :
When the device cannot boot normally, you can enter EDL mode and then use the EDL tool to flash the SPI boot firmware.
Go to the Resource Download page, download the edl-ng compressed package and unzip it, then select the corresponding version based on your system platform to download the SPI firmware.
Firmware burning
Windows$
.\edl-ng.exe --memory=spinor --loader C:\path\to\prog_firehose_ddr.elf rawprogram C:\path\to\rawprogram0.xml C:\path\to\patch0.xml
FAQ
  • If prompted Unable to loda DLL 'libusb-1.0'
Install vc_redist
