Radxa OS Boot Configuration
Radxa OS ships with three default partitions:
PartitionDefault Mount PointDescription
config/configStores system- or device-related configuration
EFI/boot/efiStores the bootloader, boot configuration, kernel image, initrd, device tree, etc.
rootfs/Root filesystem
You can use lsblk to inspect the partitions and mount points:
The following example assumes booting from a microSD card:
root@radxa-dragon-q6a:~# lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
mmcblk0 179:0 0 29.7G 0 disk
├─mmcblk0p1 179:1 0 16M 0 part /config
├─mmcblk0p2 179:2 0 1G 0 part /boot/efi
└─mmcblk0p3 179:3 0 28.7G 0 part /
If you boot from another medium such as an eMMC module, a UFS module, or an NVMe SSD, the corresponding device names will be mmcblk0 (eMMC module), sda (some UFS bridge forms), or nvme0n1 (NVMe SSD). Replace mmcblk0 in the commands below with the device name reported by lsblk.
Boot Configuration Files​
Radxa OS boot configuration files are located at:
/boot/efi/loader/entries/
Each installed kernel usually maps to one .conf file. The file name varies with the kernel version, for example:
/boot/efi/loader/entries/RadxaOS-7.0.11-3-qcom.conf
Example contents:
# cat /boot/efi/loader/entries/RadxaOS-7.0.11-3-qcom.conf
# Boot Loader Specification type#1 entry
# File created by /usr/lib/kernel/install.d/90-loaderentry.install (systemd 259.5-0ubuntu3)
title Ubuntu 26.04 LTS
version 7.0.11-3-qcom
sort-key ubuntu
options root=UUID=711cd5de-9e25-4615-bfe2-0b369aa10dc0 console=ttyMSM0,115200n8 clk_ignore_unused quiet splash loglevel=4 rw earlycon consoleblank=0 console=tty1 coherent_pool=2M irqchip.gicv3_pseudo_nmi=0 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 kasan=off plymouth.enable=0
linux /RadxaOS/7.0.11-3-qcom/linux
initrd /RadxaOS/7.0.11-3-qcom/initrd.img-7.0.11-3-qcom
Main configuration fields:
FieldDescription
titleName shown in the boot menu
versionKernel version
optionsKernel command-line parameters passed to the Linux kernel
linuxPath to the kernel image
initrdPath to the initrd image
devicetreePath to the Device Tree blob
devicetree-overlayPath to the Device Tree overlay blob
Device Tree Usage Rules​
Radxa OS follows these rules for the Device Tree:
  • By default, the boot configuration does not include a devicetree parameter; the system uses the Device Tree provided by BIOS/UEFI.
  • After a kernel update, the system may regenerate the boot configuration and explicitly set devicetree to the Device Tree shipped with the kernel package.
  • After enabling a Device Tree Overlay via rsetup, the system updates the boot configuration with the corresponding devicetree-overlay parameter.
Modifying Kernel Boot Parameters​
The following example adds the pcie_aspm=off parameter.
  1. Switch to the root user
    sudo -i
  2. Edit the kernel command line
    Open /etc/kernel/cmdline:
    nano /etc/kernel/cmdline
    Append the new parameter at the end of the line:
    pcie_aspm=off
    Modified example:
    root=UUID=711cd5de-9e25-4615-bfe2-0b369aa10dc0 console=ttyMSM0,115200n8 clk_ignore_unused quiet splash loglevel=4 rw earlycon consoleblank=0 console=tty1 coherent_pool=2M irqchip.gicv3_pseudo_nmi=0 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 kasan=off plymouth.enable=0 pcie_aspm=off
    Notes:
    • All parameters in /etc/kernel/cmdline must stay on a single line.
    • Separate parameters with spaces.
    • Do not delete required parameters such as root=UUID=....
  3. Regenerate the boot configuration for the current kernel
    kernel-install add "$(uname -r)" "/boot/vmlinuz-$(uname -r)"
  4. Verify the generated configuration
    Locate the entry for the current kernel:
    grep -l "^version[[:space:]]*$(uname -r)$" /boot/efi/loader/entries/*.conf
    Or inspect the options line of every entry:
    grep '^options' /boot/efi/loader/entries/*.conf
    Make sure the corresponding options line includes pcie_aspm=off:
    sort-key ubuntu
    options root=UUID=711cd5de-9e25-4615-bfe2-0b369aa10dc0 console=ttyMSM0,115200n8 clk_ignore_unused quiet splash loglevel=4 rw earlycon consoleblank=0 console=tty1 coherent_pool=2M irqchip.gicv3_pseudo_nmi=0 cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 kasan=off plymouth.enable=0 pcie_aspm=off
    devicetree /RadxaOS/7.0.11-3-qcom/qcs6490-radxa-dragon-q6a.dtb
  5. Reboot and verify
    reboot
    After boot, confirm the active kernel command line:
    cat /proc/cmdline
    Or check the kernel log:
    dmesg | grep 'Kernel command line'
    Expected output should include:
    pcie_aspm=off
    If the boot configuration already contains the parameter but it does not take effect after reboot, confirm that the system is actually booting the entry you just updated.
Setting the Boot Menu Timeout​
The boot menu configuration file is:
/boot/efi/loader/loader.conf
Default example — timeout 3 waits 3 seconds before booting the default entry:
timeout 3
#console-mode keep
Changing the Wait Time​
For example, set the wait time to 5 seconds:
timeout 5
Skipping the Boot Menu Wait​
If you want to boot the default entry immediately, set the timeout explicitly:
timeout 0
Commenting out timeout also speeds up booting:
#timeout 3
