Serial Port Login
Serial port login is a fundamental method for interacting with the motherboard through a UART (Universal Asynchronous Receiver/Transmitter) interface in embedded development. It allows you to view system logs and perform command-line interactions.
Hardware Connection​
danger
When using a USB-to-serial cable with the Dragon Q6A for serial port login, ensure the pins are connected correctly. Incorrect connections may damage the motherboard hardware.
It is not recommended to connect the VCC (red wire) of the USB-to-serial cable to prevent potential damage from incorrect connections.
Connect the USB-to-serial cable to the UART0 interface of the Dragon Q6A, and connect the other end to a USB port on your PC.
Dragon Q6A Pin FunctionConnection Method
Dragon Q6A: GND (Pin 6)Connect to GND pin of the USB-to-serial cable
Dragon Q6A: UART0_TXD (Pin 8)Connect to RXD pin of the USB-to-serial cable
Dragon Q6A: UART0_RXD (Pin 10)Connect to TXD pin of the USB-to-serial cable
Serial Port Login​
info
Serial Communication Parameters
  • Baud Rate: 115200
  • Data Bits: 8
  • Stop Bits: 1
  • Parity: None
  • Flow Control: None
Garbled serial output / board appears not to boot
Some serial terminal applications (for example Tabby) can drop serial data when the device redraws its output frequently, such as a boot menu that keeps redrawing itself, or apt / dpkg style progress output that rewrites the same line or repositions the cursor. The boot log then shows many half-finished lines and repeated messages, the login prompt never appears, and the board looks like it failed to boot or hung — even though the system actually booted normally.
This is a display issue in the terminal application, not a board fault. If you hit it, use a serial terminal that has been verified to render the same output correctly, such as picocom:
Press Ctrl+A Ctrl+X to exit picocom.
Using Tabby​
Download Tabby​
Install Tabby​
Using Tabby​
Serial Port Configuration​
Select Serial Port Template​
Modify Serial Port Parameters​
③ --> Baud rate : Set the baud rate to 115200
Serial Port Device Number
Login via Serial Port​
Serial Port Cannot Be Opened
If you see the error Error: Permission denied, cannot open /dev/ttyUSB*, the current user does not have permission to access the serial port device. First confirm the serial device number corresponding to your board, e.g. /dev/ttyUSB0, then run:
sudo chmod 666 /dev/ttyUSB0
This method may no longer work after a reboot or replugging the device. It is recommended to permanently add the current user to the serial port user group:
After that, log out and log back in for the permission change to take effect.
After a successful connection, press Enter to display the login prompt. Then use the corresponding system username and password to log in (the password will not be displayed as you type; press Enter after entering the password).
Android System Login
Android system login does not require entering user account and password.
Using the Serial Port​
After successfully logging in to the system via the serial port, you can view system logs and run commands to test system functionality.
