ConvNext-Base Example
This document describes using the QAI AppBuilder Python API to perform inference with the ConvNext-Base target recognition model using Qualcomm® Hexagon™ Processor (NPU).
Supported Devices
| Device | SoC |
| Dragon Q6A | QCS6490 |
| Dragon Q8B | SC8280XP |
Install QAI AppBuilder
Please install QAI AppBuilder according to QAI AppBuilder Installation Guide.
Please configure QAIRT environment variables according to Configure QAIRT Environment Variables.
Run Example
Install Dependencies
Run Script
Navigate to the example directory
- QCS6490
- SC8280XP
Devicecd ai-engine-direct-helper/samples/linux/pythonDevicecd ai-engine-direct-helper/samples/linux/python -
Prepare input image, using the following image as input example
input image
Execute inference
Devicepython3 convnext_base/convnext_base.py$ python3 convnext_base/convnext_base.py
Current file directory: /mnt/ssd/qualcomm/701/zzf_fork/ai-engine-direct-helper/samples/linux/python/convnext_base
193.9ms [WARNING] Time: Read model file to memory. 71.69
269.5ms [WARNING] Time: contextCreateFromBinary. 75.47
269.5ms [WARNING] Time: UnmapViewOfFile. 0.00
270.9ms [WARNING] Time: model_initialize convnext_base 270.85
348.3ms [WARNING] Time: model_inference convnext_base 30.17
Top 5 predictions for image:
Samoyed 0.8726790547
Pomeranian 0.0192712061
keeshond 0.0150661934
Japanese spaniel 0.0032834315
Eskimo dog 0.0020474677
365.5ms [WARNING] Time: model_destroy convnext_base 14.44The printed results show that
Samoyedhas the highest confidence, which matches the input image content.
