ConvNext-Tiny Example
This document describes using the QAI AppBuilder Python API to perform inference with the ConvNext-Tiny target recognition model using Qualcomm® Hexagon™ Processor (NPU).
Supported Devices
| Device | SoC |
| Dragon Q6A | QCS6490 |
| Dragon Q8B | SC8280XP |
Install QAI AppBuilder
Please install QAI AppBuilder according to QAI AppBuilder Installation Guide.
Please configure QAIRT environment variables according to Configure QAIRT Environment Variables.
Run Example
Install Dependencies
Run Script
Navigate to the example directory
- QCS6490
- SC8280XP
Devicecd ai-engine-direct-helper/samples/linux/pythonDevicecd ai-engine-direct-helper/samples/linux/python -
Prepare input image, using the following image as input example
input image
Execute inference
Devicepython3 convnext_tiny/convnext_tiny.py$ python3 convnext_tiny/convnext_tiny.py
Current file directory: /mnt/ssd/qualcomm/701/zzf_fork/ai-engine-direct-helper/samples/linux/python/convnext_tiny
132.1ms [WARNING] Time: Read model file to memory. 15.88
176.1ms [WARNING] Time: contextCreateFromBinary. 44.01
176.2ms [WARNING] Time: UnmapViewOfFile. 0.00
176.6ms [WARNING] Time: model_initialize convnext_tiny 176.53
245.2ms [WARNING] Time: model_inference convnext_tiny 11.95
Top 5 predictions for image:
Samoyed 0.637629509
Pomeranian 0.1382825226
keeshond 0.0217001885
Arctic fox 0.0138142202
white wolf 0.0115938596
263.1ms [WARNING] Time: model_destroy convnext_tiny 15.29The printed results show that
Samoyedhas the highest confidence, which matches the input image content.
