EfficientNet-B0 Example
This document describes using the QAI AppBuilder Python API to perform inference with the EfficientNet-B0 target recognition model using Qualcomm® Hexagon™ Processor (NPU).
Supported Devices
| Device | SoC |
| Dragon Q6A | QCS6490 |
| Dragon Q8B | SC8280XP |
Install QAI AppBuilder
Please install QAI AppBuilder according to QAI AppBuilder Installation Guide.
Please configure ADSP environment variables according to Create ADSP Environment Variables.
Run Example
Install Dependencies
Run Script
Navigate to the example directory
- QCS6490
- SC8280XP
Devicecd ai-engine-direct-helper/samples/linux/pythonDevicecd ai-engine-direct-helper/samples/linux/python -
Prepare input image, using the following image as input example
input image
Execute inference
Devicepython3 efficientnet_b0/efficientnet_b0.py$ python3 efficientnet_b0/efficientnet_b0.py
Current file directory: /mnt/ssd/qualcomm/701/zzf_fork/ai-engine-direct-helper/samples/linux/python/efficientnet_b0
122.3ms [WARNING] Time: Read model file to memory. 5.33
143.3ms [WARNING] Time: contextCreateFromBinary. 20.87
143.3ms [WARNING] Time: UnmapViewOfFile. 0.00
143.7ms [WARNING] Time: model_initialize efficientnet_b0 143.64
214.6ms [WARNING] Time: model_inference efficientnet_b0 6.08
Top 5 predictions for image:
Samoyed 0.6965298057
Pomeranian 0.1052966565
keeshond 0.0131986532
Eskimo dog 0.0075131184
Arctic fox 0.0056676473
235.9ms [WARNING] Time: model_destroy efficientnet_b0 18.66The printed results show that
Samoyedhas the highest confidence, which matches the input image content.
