EfficientNet-B4 Example
This document describes using the QAI AppBuilder Python API to perform inference with the EfficientNet-B4 target recognition model using Qualcomm® Hexagon™ Processor (NPU).
Supported Devices
| Device | SoC |
| Dragon Q6A | QCS6490 |
| Dragon Q8B | SC8280XP |
Install QAI AppBuilder
Please install QAI AppBuilder according to QAI AppBuilder Installation Guide.
Please configure ADSP environment variables according to Create ADSP Environment Variables.
Run Example
Install Dependencies
Run Script
Navigate to the example directory
- QCS6490
- SC8280XP
Devicecd ai-engine-direct-helper/samples/linux/pythonDevicecd ai-engine-direct-helper/samples/linux/python -
Prepare input image, using the following image as input example
input image
Execute inference
Devicepython3 efficientnet_b4/efficientnet_b4.py$ python3 efficientnet_b4/efficientnet_b4.py
Current file directory: /mnt/ssd/qualcomm/701/zzf_fork/ai-engine-direct-helper/samples/linux/python/efficientnet_b4
134.2ms [WARNING] Time: Read model file to memory. 15.52
197.4ms [WARNING] Time: contextCreateFromBinary. 63.07
197.4ms [WARNING] Time: UnmapViewOfFile. 0.00
197.8ms [WARNING] Time: model_initialize efficientnet_b4 197.73
271.4ms [WARNING] Time: model_inference efficientnet_b4 12.60
Top 5 predictions for image:
Samoyed 0.9568610787
Pomeranian 0.0066686491
keeshond 0.0054634647
chow 0.0010403089
Eskimo dog 0.0007608762
287.8ms [WARNING] Time: model_destroy efficientnet_b4 13.65The printed results show that
Samoyedhas the highest confidence, which matches the input image content.
