EfficientNet-V2-s Example
This document describes using the QAI AppBuilder Python API to perform inference with the EfficientNet-V2-s target recognition model using Qualcomm® Hexagon™ Processor (NPU).
Supported Devices
DeviceSoC
Dragon Q6AQCS6490
Dragon Q8BSC8280XP
Install QAI AppBuilder
  1. Please install QAI AppBuilder according to QAI AppBuilder Installation Guide.
  2. Please configure ADSP environment variables according to Create ADSP Environment Variables.
Run Example
Install Dependencies
Run Script
  • Navigate to the example directory
    cd ai-engine-direct-helper/samples/linux/python
  • Prepare input image, using the following image as input example
    input image
  • Execute inference
    python3 efficientnet_v2_s/efficientnet_v2_s.py
    $ python3 efficientnet_v2_s/efficientnet_v2_s.py
    Current file directory: /mnt/ssd/qualcomm/701/zzf_fork/ai-engine-direct-helper/samples/linux/python/efficientnet_v2_s
    129.0ms [WARNING] Time: Read model file to memory. 11.18
    158.9ms [WARNING] Time: contextCreateFromBinary. 29.89
    159.0ms [WARNING] Time: UnmapViewOfFile. 0.00
    159.4ms [WARNING] Time: model_initialize efficientnet_v2_s 159.34
    227.4ms [WARNING] Time: model_inference efficientnet_v2_s 10.06
    Top 5 predictions for image:
    Samoyed 0.7607400417
    keeshond 0.0230328161
    Pomeranian 0.0204458293
    white wolf 0.0193288065
    Arctic fox 0.0062915389
    239.8ms [WARNING] Time: model_destroy efficientnet_v2_s 9.40
    The printed results show that Samoyed has the highest confidence, which matches the input image content.
