FCN-ResNet50 Example
This document describes using the QAI AppBuilder Python API to perform inference with the FCN-ResNet50 image segmentation model using Qualcomm® Hexagon™ Processor (NPU).
Supported Devices
DeviceSoC
Dragon Q6AQCS6490
Dragon Q8BSC8280XP
Install QAI AppBuilder
  1. Please install QAI AppBuilder according to QAI AppBuilder Installation Guide.
  2. Please configure ADSP environment variables according to Create ADSP Environment Variables.
Run Example
Install Dependencies
Run Script
  • Navigate to the example directory
    cd ai-engine-direct-helper/samples/linux/python
  • Prepare input image, using the following image as input example
    input image
  • Execute inference
    python3 fcn_resnet50/fcn_resnet50.py --image ./input.jpg
    $ python3 fcn_resnet50/fcn_resnet50.py --image ./input.jpg
    Current file directory: /mnt/ssd/git_clone/ai-engine-direct-helper/samples/linux/python/fcn_resnet50
    127.2ms [WARNING] Time: Read model file to memory. 12.72
    185.9ms [WARNING] Time: contextCreateFromBinary. 58.58
    186.0ms [WARNING] Time: UnmapViewOfFile. 0.00
    187.1ms [WARNING] Time: model_initialize fcn_resnet50 187.09
    385.4ms [WARNING] Time: model_inference fcn_resnet50 112.79
    463.2ms [WARNING] Time: model_destroy fcn_resnet50 10.20
  • Output results
    output image
