Real-ESRGAN-General-x4v3 Example
This document describes using the QAI AppBuilder Python API to run inference with the Real-ESRGAN-General-x4v3 super-resolution model on the Qualcomm® Hexagon™ Processor (NPU).
Supported devices
DeviceSoC
Dragon Q6AQCS6490
Dragon Q8BSC8280XP
Fogwise® AIRbox Q900QCS9075
Install QAI AppBuilder​
Run the sample​
Install dependencies​
Run the script​
    cd qai-appbuilder/samples
Run inference (Linux requires --chipset, or model download may fail)
SC8280XP and QCS6490 both use Hexagon V68. Use --chipset 6490 when downloading models.
python3 ComputerVision/Super_Resolution/real_esrgan_general_x4v3/real_esrgan_general_x4v3.py --chipset 6490
Expected result​
On Dragon Q6A, a successful run writes:
ComputerVision/Super_Resolution/real_esrgan_general_x4v3/output.jpg
Without a display, Error: no DISPLAY environment variable specified may appear; ignore it if the output file exists and the exit code is 0.
Launcher alternative:
python3 run_inference.py --model real_esrgan_general_x4v3 --args "--chipset 6490"
