SESR-M5 Example
This document describes using the QAI AppBuilder Python API to perform inference with the SESR-M5 image super-resolution model using Qualcomm® Hexagon™ Processor (NPU).
Supported Devices
DeviceSoC
Dragon Q6AQCS6490
Dragon Q8BSC8280XP
Install QAI AppBuilder
  1. Please install QAI AppBuilder according to QAI AppBuilder Installation Guide.
  2. Please configure ADSP environment variables according to Create ADSP Environment Variables.
Run Example
Install Dependencies
Run Script
  • Navigate to the example directory
    cd ai-engine-direct-helper/samples/linux/python
  • Prepare input image, using the following image as input example
    input image
  • Execute inference
    python3 sesr_m5/sesr_m5.py
    $ python3 sesr_m5/sesr_m5.py
    Current file directory: /mnt/ssd/qualcomm/701/zzf_fork/ai-engine-direct-helper/samples/linux/python/sesr_m5
    113.8ms [WARNING] Time: Read model file to memory. 0.39
    119.7ms [WARNING] Time: contextCreateFromBinary. 5.87
    119.8ms [WARNING] Time: UnmapViewOfFile. 0.00
    119.9ms [WARNING] Time: model_initialize sesr_m5 119.89
    152.4ms [WARNING] Time: model_inference sesr_m5 11.00
    330.6ms [WARNING] Time: model_destroy sesr_m5 18.65
    /usr/bin/xdg-open: 882: www-browser: not found
    /usr/bin/xdg-open: 882: links2: not found
    /usr/bin/xdg-open: 882: elinks: not found
    /usr/bin/xdg-open: 882: links: not found
    /usr/bin/xdg-open: 882: lynx: not found
    /usr/bin/xdg-open: 882: w3m: not found
    xdg-open: no method available for opening '/tmp/tmpxodzub9w.PNG'
    output image
