SqueezeNet-1.1 Example
This document describes using the QAI AppBuilder Python API to perform inference with the SqueezeNet-1.1 target recognition model using Qualcomm® Hexagon™ Processor (NPU).
Supported Devices
DeviceSoC
Dragon Q6AQCS6490
Dragon Q8BSC8280XP
Install QAI AppBuilder
  1. Please install QAI AppBuilder according to QAI AppBuilder Installation Guide.
  2. Please configure ADSP environment variables according to Create ADSP Environment Variables.
Run Example
Install Dependencies
Run Script
  • Navigate to the example directory
    cd ai-engine-direct-helper/samples/linux/python
  • Prepare input image, using the following image as input example
    input image
  • Execute inference
    python3 squeezenet1_1/squeezenet1_1.py
    $ python3 squeezenet1_1/squeezenet1_1.py
    Current file directory: /mnt/ssd/qualcomm/701/zzf_fork/ai-engine-direct-helper/samples/linux/python/squeezenet1_1
    120.9ms [WARNING] Time: Read model file to memory. 2.75
    132.8ms [WARNING] Time: contextCreateFromBinary. 11.81
    133.0ms [WARNING] Time: UnmapViewOfFile. 0.00
    133.2ms [WARNING] Time: model_initialize squeezenet1_1 133.16
    225.5ms [WARNING] Time: model_inference squeezenet1_1 2.50
    Top 5 predictions for image:
    Samoyed 0.8289067745
    wallaby 0.0915796161
    Pomeranian 0.0265247617
    Great Pyrenees 0.0101179369
    hare 0.0050830133
    249.2ms [WARNING] Time: model_destroy squeezenet1_1 20.91
    The printed results show that Samoyed has the highest confidence, which matches the input image content.
