Booting from MicroSD Card and Installing System to NVMe SSD
This guide explains how to install the system to an NVMe SSD using the dd command when the system can boot normally from a MicroSD card.
Installing the system will format the NVMe SSD. Please back up any important data in advance!
Prerequisites
To use the dd command to install the system to an NVMe SSD, you need to meet the following conditions:
- The system can boot normally from a MicroSD card
- NVMe SSD is installed on the board
Hardware Connection
Install the NVMe SSD on the board, connect a display, and power the board using a power adapter.
- M.2 M 2280 Slot
- M.2 M 2230 Slot
- PCIe FPC Interface
Install NVMe SSD via M.2 M Key 2280 interface.
Install NVMe SSD via M.2 M Key 2230 Slot.
NVMe SSD can be installed using PCIe FPC interface with M.2 M Key HAT.
System Installation
Download System Image
Access the Resource Download page from your device and download the latest system image to the device.
You can use the wget command to download the system image file to your device.
sudo apt install wget -y
wget <download_url>
Where <download_url> is the download URL of the system image file. You can copy the latest image download URL from the Resource Download page to replace it.
Download example:
wget https://github.com/radxa-build/radxa-dragon-midstream/releases/download/rsdk-r7/radxa-dragon-midstream_resolute_gnome_r7.output_512.img.xz
Extract System Image
Our system images are generally in *.img.xz format and need to be extracted before use.
sudo apt install xz-utils -y
unxz <path_to_image_unxz>
Where <path_to_image_unxz> is the path to the system image file, which needs to be replaced with the actual system image file path.
Extraction example:
unxz radxa-dragon-midstream_resolute_gnome_r7.output_512.img.xz
Determine Device Path
You can use the lsblk command to check the device path and determine it based on the disk capacity.
Note: If the disk capacities are similar, you can safely remove and reinsert the NVMe SSD to observe which device path appears and disappears, thus determining the correct device path.
lsblk
If the system recognizes the NVMe device, it will typically be identified as a /dev/nvme*n* device. If there are multiple storage devices, you can determine the corresponding device path by safely removing and reinserting the device.
Terminal output example:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
nvme0n1 259:0 0 119.2G 0 disk
└─nvme0n1p1 259:1 0 119.2G 0 part
Install System Image
Use the dd command to install the system image to the NVMe SSD.
Write example:
sudo dd if=radxa-dragon-midstream_resolute_gnome_r7.output_512.img of=/dev/nvme0n1 bs=4M status=progress
Parameter description:
<path_to_image>: The path to the system image file, which needs to be replaced with the actual system image file path. -
<device_target>: The device path of the NVMe SSD module, which needs to be replaced with the actual NVMe SSD module's device path. -
bs=4M: Block size for writing. -
status=progress: Display write progress.
Verify Write Result
After the system installation is complete, you can use the lsblk command to check if the NVMe SSD partition table has been created correctly.
lsblk
├─nvme0n1p1 259:3 0 16M 0 part
├─nvme0n1p2 259:4 0 300M 0 part
└─nvme0n1p3 259:5 0 6.3G 0 part
Booting the System
After installing the system, remove the microSD card, confirm that the NVMe SSD is installed in the Dragon Q8B NVMe SSD slot, then power the Dragon Q8B with a 20V Type-C power adapter.
Confirm that the NVMe SSD is installed
Connect the monitor and board using HDMI or a dual-ended USB-C cable
Power the Dragon Q8B with a 20V Type-C power adapter
After the system boots normally, the power LED turns green and the status LED blinks blue.
Logging into the System
When you boot the system for the first time, log in with the default username and password.
The default credentials for Radxa OS are:
| Item | Value |
| Username | radxa |
| Password | radxa |
Using the System
After the system boots successfully, you can start using Radxa OS on the Dragon Q8B. For basic Radxa OS usage, refer to Use the System guide.
