Flash System Image to UFS
This guide explains how to flash a system image to UFS storage using a USB Type-C cable.
Prerequisites
Install the UFS module into the board's UFS module slot
Put the board into EDL mode and connect it to your computer using a USB Type-C cable --> Refer to the Entering EDL Mode guide
Set up the EDL tool environment --> Refer to the Using EDL Tool guide
Download System Image
You need to visit the Downloads page to download the latest system image.
Flash System via USB
You need to copy the extracted system image file to the SPI boot firmware's \flat_build\spinor\dragon-q8b\ directory, then open a terminal in that folder and run the following command to flash the system image:
# Method 1: Flash using rawprogram XML files (recommended)
# Method 2: Write raw sectors directly
Parameter Description:
<path-to-loader>: Path to the bootloader, replace with the actual bootloader path. -
<storage-type>: Storage type, replace with the actual storage type. -
<start-sector>: Starting sector, replace with the actual starting sector. -
<path-to-image-file>: Path to the system image file, replace with the actual system image file path.
Example:
edl-ng --loader prog_firehose_ddr.elf --memory ufs write-sector 0 radxa-dragon-midstream_resolute_gnome_r7.output_4096.img
How to tell whether flashing succeeded
After you run edl-ng ... rawprogram ..., the terminal will show the write progress for each partition. If flashing succeeds, you should see output similar to:
If you see output like this and it shows command finished successfully at the end, the image write is complete.
If you see Error: Image file ... not found but it still shows command finished successfully at the end, you can ignore this error - it's just because some optional partition files don't exist.
Common failure signs
If the terminal doesn't show command finished successfully, or instead prints errors such as Error: / Operation Error: / IO Error: / Platform Error:, then the flash did not complete successfully. Common examples include:
An unexpected error occurred in 'write-sector': <specific error message>
If flashing fails, first check:
- Whether the board has actually entered EDL mode.
- Whether the
prog_firehose_ddr.elfpath is correct. - Whether the storage type matches the target media (for example
ufs,Sdcc --slot 0, ornvme). - Whether the image file has been fully extracted and the path is correct.
- Whether the USB data cable and the board-to-host connection are stable.
