UART Debug
UART debugging is a core method in embedded development for interacting with the motherboard through a serial communication interface (UART). It allows you to view system output and perform debugging using serial port tools.
Hardware Connection
① : Power on the motherboard using a power adapter
② : Connect the motherboard's Debug port to your computer's USB port using a USB Type-C cable
If the motherboard enters Maskrom mode and you connect the Debug port to your computer's USB port using a USB Type-C cable, the system will show two devices, similar to the following information:
Bus 001 Device 014: ID 1a86:7523 QinHeng Electronics CH340 serial converter
Bus 001 Device 015: ID 2207:350c Fuzhou Rockchip Electronics Company
Where Bus 001 Device 014 is the CH340 serial debug device, and Bus 001 Device 015 is the motherboard's Maskrom mode device.
Serial Port Login
Baud Rate: 1500000
Data Bits: 8
Stop Bits: 1
Parity: None
Flow Control: None
Using Tabby
Download Tabby
Install Tabby
Using Tabby
Serial Port Configuration
Select Serial Port Template
Modify Serial Port Parameters
③ --> Baud rate : Set the baud rate to 1500000
Login via Serial Port
After a successful connection, press Enter to display the login prompt. Then use the corresponding system username and password to log in (the password will not be displayed as you type; press Enter after entering the password).
Android system login does not require entering user account and password.
Using the Serial Port
After successfully logging in to the system via the serial port, you can view system logs and run commands to test system functionality.
