Interface Usage
Interface Overview​
E24C Bare Board Interfaces
No.DescriptionQty
①Power Interface: DC55251
②Onboard eMMC (optional; mutually exclusive with SPI Nor Flash for boot)1
③USB 2.0 Type-C: Combined Device & Debug Port1
④User Button1
⑤USB 2.0 Type-A Ports3
⑥RTC Battery Connector1
⑦microSD Card Slot1
⑧GPIO: 14-Pin Expansion Header1
⑨LED Indicators (1 Power, 4 Ethernet Port LEDs)5
⑩Power Button1
⑪Fan Header1
⑫Maskrom Button1
⑬Gigabit Ethernet Ports (Configurable WAN/LAN)4
⑭HDMI 2.1 Output1
⑮M.2 NVMe SSD Slot1
⑯SPI Nor Flash (boot device on some models; mutually exclusive with eMMC)1
Interface Description​
This section describes the interfaces using the Radxa E24C bare board as an example.
Power Interface​
Powered by a 12V/2A power adapter with a DC5525 connector.
Recommended power supplies:
Onboard eMMC​
Optional onboard eMMC storage configuration. Note: Some models use SPI Nor Flash for boot; this is mutually exclusive with onboard eMMC.
USB 2.0 Type-C Port​
Serves as a debug port for viewing logs and accessing the device, with a default baud rate of 1500000.
As a data transfer interface, it supports USB 2.0 OTG data transfer and serial debugging.
  • USB 2.0 OTG
Supports ADB, USB network, and mass storage.
Example for USB mass storage (ensure SSD is connected via M.2 M-Key before executing commands):
radxa@radxa-e24c$
modprobe libcomposite
modprobe usb_f_mass_storage
systemctl daemon-reload
umount /sys/kernel/config
mount -t configfs none /sys/kernel/config
cd /sys/kernel/config/usb_gadget
mkdir -p my_udisk
cd my_udisk
echo 0x1d6b > idVendor
echo 0x0104 > idProduct
echo 0x0100 > bcdDevice
echo 0x0300 > bcdUSB
mkdir -p strings/0x409
echo "123456789" > strings/0x409/serialnumber
echo "My Manufacturer" > strings/0x409/manufacturer
echo "My USB Disk" > strings/0x409/product
mkdir -p configs/c.1
mkdir -p configs/c.1/strings/0x409
echo "Mass Storage Config" > configs/c.1/strings/0x409/configuration
mkdir -p functions/mass_storage.usb0
mkfs.ext4 /dev/nvme0n1p1
echo /dev/nvme0n1p1 > functions/mass_storage.usb0/lun.0/file
ln -s functions/mass_storage.usb0 configs/c.1
echo fc000000.usb > UDC
User Button​
Programmable button with software-configurable functionality.
USB 2.0 Type-A Ports​
Three USB 2.0 ports for connecting external devices such as keyboards, mice, and storage devices.
RTC Battery Connector​
2-Pin 1.25mm RTC battery connector for connecting a real-time clock battery to maintain accurate system time during power loss.
microSD Card Slot​
For inserting a microSD card, which can be used as a system boot device or for additional storage.
GPIO: 14-Pin Expansion Header​
14-Pin 0.1" (2.54mm) interface supporting multiple functions including SPI, UART, I2C, and power output.
E24C GPIO Pinout Diagram
GPIO Pin Definition Table​
Pin#Function 1Function 2
1VCC_3V3
2VCC5V0_SYS
3GPIO1_B3I2C5_SDA_M0
4GND
5GPIO1_B2I2C5_SCL_M0
6GPIO4_A4
7GPIO1_B7SPI1_MOSI
8GPIO4_A5
9GPIO1_C0SPI1_MISO
10GPIO4_A6UART1_TX_M0
11GPIO1_B6SPI1_CLK
12GPIO4_B4
13GPIO1_C1SPI1_CSN0
14GPIO4_A7UART1_RX_M0
warning
All signal pins are 3.3V level. Do not connect 5V signals as this may damage the single-board computer.
GPIO Usage Example​
radxa@radxa-e24c$
# Install GPIO control tools
sudo apt-get install gpiod
# List available GPIO chips
gpiodetect
# View GPIO status
gpioinfo
# Control GPIO output
gpioset <chip> <line>=<value>
# Read GPIO input
gpioget <chip> <line>
Common Peripheral Connection Examples​
I2C Sensor Connection​
radxa@radxa-e24c$
# Install I2C tools
sudo apt-get install i2c-tools
# Scan for I2C devices
sudo i2cdetect -y 2 # Assuming I2C2 is used
# Read I2C device register
sudo i2cget -y 2 0x48 0x00 # Read register 0x00 from device at address 0x48
# Write to I2C device register
sudo i2cset -y 2 0x48 0x01 0x55 # Write 0x55 to register 0x01 of device at address 0x48
LED Status Indicators​
Five status indicators showing power and network status. Refer to the silkscreen on the Radxa E24C bare board to identify each indicator.
  • Power LED: Green light when power is connected
  • Network Status LEDs: Blink in sync with corresponding network port activity
Power Button​
Used to power the device on and off.
Fan Header​
2-Pin 1.25mm fan header for connecting a cooling fan.
Maskrom Button​
Used to enter Maskrom mode for firmware flashing.
Gigabit Ethernet Ports​
Four Gigabit Ethernet ports.
In OpenWrt systems, these interfaces can be flexibly configured as WAN (Wide Area Network) or LAN (Local Area Network) ports, providing a highly customizable networking solution. Multiple ports also offer redundancy and load balancing capabilities, enhancing network reliability and performance.
  • Unique MAC Address
The Radxa E24C has a unique and fixed MAC address that remains consistent across power cycles, reboots, and even after reflashing the firmware.
  • Network Speed Test
radxa@radxa-e24c$
# Install iperf3 tool
sudo apt install iperf3
# Run on the server side
iperf -s
# Test upload speed
iperf3 -c server-ip -t 60
# Test download speed
iperf3 -c server-ip -t 60 -R
HDMI 2.1 Output Port​
Supports video output up to 4K resolution, compatible with monitors and TVs.
M.2 NVMe SSD Interface​
Provides a PCIe 2.1 1-lane interface for connecting M.2 NVMe SSDs. Supports standard M.2 2280 form factor NVMe SSDs. Note: M.2 SATA SSDs are not supported.
