UART Debug
UART debugging is a core method in embedded development for interacting with the motherboard through a serial communication interface (UART). It allows you to view system output and perform debugging using serial port tools.
Hardware Connection
① : Power on the motherboard using a power adapter
② : Connect the motherboard's Debug port to your computer's USB port using a USB Type-C cable
If the motherboard enters Maskrom mode and you connect the Debug port to your computer's USB port using a USB Type-C cable, the system will show two devices, similar to the following information:
Bus 001 Device 014: ID 1a86:7523 QinHeng Electronics CH340 serial converter
Bus 001 Device 015: ID 2207:350c Fuzhou Rockchip Electronics Company
Where Bus 001 Device 014 is the CH340 serial debug device, and Bus 001 Device 015 is the motherboard's Maskrom mode device.
Serial Port Login
Baud Rate: 1500000
Data Bits: 8
Stop Bits: 1
Parity: None
Flow Control: None
Some serial terminal applications (for example Tabby) can drop serial data when the device redraws its output frequently, such as a boot menu that keeps redrawing itself, or apt / dpkg style progress output that rewrites the same line or repositions the cursor. The boot log then shows many half-finished lines and repeated messages, the login prompt never appears, and the board looks like it failed to boot or hung — even though the system actually booted normally.
This is a display issue in the terminal application, not a board fault. If you hit it, use a serial terminal that has been verified to render the same output correctly, such as picocom:
Press Ctrl+A Ctrl+X to exit picocom.
Using Tabby
Download Tabby
Install Tabby
Using Tabby
Serial Port Configuration
Select Serial Port Template
Modify Serial Port Parameters
③ --> Baud rate : Set the baud rate to 1500000
Login via Serial Port
If you see the error Error: Permission denied, cannot open /dev/ttyUSB*, the current user does not have permission to access the serial port device. First confirm the serial device number corresponding to your board, e.g. /dev/ttyUSB0, then run:
sudo chmod 666 /dev/ttyUSB0
This method may no longer work after a reboot or replugging the device. It is recommended to permanently add the current user to the serial port user group:
After that, log out and log back in for the permission change to take effect.
After a successful connection, press Enter to display the login prompt. Then use the corresponding system username and password to log in (the password will not be displayed as you type; press Enter after entering the password).
Android system login does not require entering user account and password.
Using the Serial Port
After successfully logging in to the system via the serial port, you can view system logs and run commands to test system functionality.
