Interface Usage Guide
Interface Overview​
e54c-board-label
Interface Description​
Power Status LED​
Power status indicator, lights up green when the device is powered on.
Network Status LEDs​
Four network port status indicators that light up according to the signal changes of each network port.
User Button​
User-programmable button, functionality can be customized through software.
Power Button​
Used to turn the device on and off.
12V DC Power Connector​
Power input, Radxa E54C uses 12V voltage input with a standard 5525 DC connector. Please refer to Power Supply Options.
Gigabit Ethernet Ports​
Radxa E54C provides four gigabit Ethernet ports. In an OpenWrt system, these interfaces can be flexibly configured as WAN (Wide Area Network interface) or LAN (Local Area Network interface) ports, providing users with highly customizable network solutions. Multiple ports also provide redundancy and load balancing capabilities, enhancing network reliability and performance.
Unique MAC Address​
The MAC address of Radxa E54C is unique and fixed. It remains unchanged after each power cycle or software restart, and even after reflashing the system.
Network Speed Testing​
  • Install the iperf3 tool
root@radxa-e54c#
sudo apt-get install iperf3
  • Run the command on the server side:
linux-host$
iperf -s
  • Speed Testing
  1. Test upload speed
root@radxa-e54c#
iperf3 -c server-ip -t 60
  1. Test download speed
linux-host$
iperf3 -c server-ip -t 60 -R
USB Type-C Port​
Used as a debug port for viewing logs and accessing the device, with a default baud rate of 1500000.
Also serves as a data transfer interface, supporting USB3.0 OTG, firmware flashing, and DP display output.
USB3.0 OTG​
Supports adb.
Supports usbnet.
Supports mass storage.
USB Mass Storage with NVMe SSD​
The following example demonstrates setting up USB mass storage using an NVMe SSD. Make sure to connect an SSD to the M-Key slot before executing these commands.
root@radxa-e54c#
modprobe libcomposite
modprobe usb_f_mass_storage
systemctl daemon-reload
umount /sys/kernel/config
mount -t configfs none /sys/kernel/config
cd /sys/kernel/config/usb_gadget
mkdir -p my_udisk
cd my_udisk
echo 0x1d6b > idVendor
echo 0x0104 > idProduct
echo 0x0100 > bcdDevice
echo 0x0300 > bcdUSB
mkdir -p strings/0x409
echo "123456789" > strings/0x409/serialnumber
echo "My Manufacturer" > strings/0x409/manufacturer
echo "My USB Disk" > strings/0x409/product
mkdir -p configs/c.1
mkdir -p configs/c.1/strings/0x409
echo "Mass Storage Config" > configs/c.1/strings/0x409/configuration
mkdir -p functions/mass_storage.usb0
mkfs.ext4 /dev/nvme0n1p1
echo /dev/nvme0n1p1 > functions/mass_storage.usb0/lun.0/file
ln -s functions/mass_storage.usb0 configs/c.1
echo fc000000.usb > UDC
The above commands configure USB 3.0 mass storage. If you need USB 2.0 mass storage configuration, simply change echo 0x0300 > bcdUSB to echo 0x0200 > bcdUSB.
Connect your PC to the E54C using a USB Type-A to Type-C cable, and the following will appear on your PC:
linux-host$
$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sdb 8:16 1 953.9G 0 disk /media/devmon/sdb-usb-Linux_File-Stor_
You can copy files to this mass storage device:
linux-host$
$ lsblk
cp /home/lsj/Downloads/test.wav /media/devmon/sdb-usb-Linux_File-Stor_
md5sum /media/devmon/sdb-usb-Linux_File-Stor_/test.wav
View on the E54C:
root@radxa-e54c#
mount /dev/nvme0n1p1 /mnt/
ls /mnt/
md5sum /mnt/test.wav
DP Display​
Supports 4K resolution. Note that the display will require separate power supply.
Maskrom Button​
Maskrom button is used to enter Maskrom mode for flashing firmware.
HDMI 2.1 Port​
Supports video output with resolutions up to 8K, allowing connection to monitors or TVs.
USB 3.0 Type-A Port​
Provides a high-speed USB 3.0 interface for connecting external devices such as storage devices, network adapters, etc.
USB 2.0 Type-A Ports​
Provides two USB 2.0 interfaces for connecting external devices such as keyboards, mice, storage devices, etc.
Peripheral Connection Testing​
Repeatedly connect and disconnect USB peripherals to ensure they are recognized properly each time and function normally.
Storage device recognition:
root@radxa-e54c#
$ lsusb
Bus 001 Device 003: ID 067b:2731 Prolific Technology, Inc. USB SD Card Reader
As shown above, a Micro-SD Card Reader has been successfully recognized.
Transfer Rate Testing​
  1. Identify the USB storage device
Use lsblk to confirm the USB storage device
root@radxa-e54c#
$ lsblk
sda 8:0 1 29.3G 0 disk
├─sda1 8:1 1 256M 0 part
└─sda2 8:2 1 29G 0 part
mmcblk0 179:0 0 14.5G 0 disk
├─mmcblk0p1 179:1 0 256M 0 part /boot
└─mmcblk0p2 179:2 0 14.2G 0 part /
  1. Test read/write speeds
root@radxa-e54c#
# Test write speed
dd if=/dev/zero of=/mnt/usb/test.img bs=1M count=1024 oflag=direct
# Test read speed
dd if=/mnt/usb/test.img of=/dev/null bs=1M count=1024 iflag=direct
microSD Card Slot​
Used for inserting a microSD storage card, which can serve as a system boot drive or additional storage space.
M.2 M-Key Slot​
Provides a PCIe 2.1 1-lane interface for connecting M.2 NVMe SSDs. Supports standard M.2 2280 form factor NVMe SSDs. Note that M.2 SATA SSDs are not supported.
Installing an NVMe SSD​
  1. Make sure the device is powered off and disconnected from power
  2. Insert the M.2 NVMe SSD into the M.2 M-Key slot
  3. Secure the SSD with the screw
  4. Connect power and start the device
Testing NVMe SSD Performance​
root@radxa-e54c#
# Install testing tools
sudo apt-get install hdparm
# Test read performance
sudo hdparm -t /dev/nvme0n1
# Use dd to test write performance
sudo dd if=/dev/zero of=/mnt/nvme/test.img bs=1M count=1024 oflag=direct
GPIO Expansion Header​
A 14-Pin 0.1" (2.54mm) interface that supports various interface functions:
  • 1x SPI
  • 1x UART
  • 1x I2C
  • 2x 5V power outputs
  • 1x 3.3V power output
GPIO Usage Example​
root@radxa-e54c#
# Install GPIO control tools
sudo apt-get install gpiod
# List available GPIO chips
gpiodetect
# View GPIO status
gpioinfo
# Control GPIO output
gpioset <chip> <line>=<value>
# Read GPIO input
gpioget <chip> <line>
Fan Connector​
2-Pin 1.25mm fan connector for connecting a cooling fan.
RTC Battery Connector​
2-Pin 1.25mm RTC battery connector for connecting a real-time clock battery, which keeps the system time accurate even after power is disconnected.
