Hardware Interfaces and Design
Hardware Overview​
Radxa E54C is a high-performance edge AI network computing device, powered by the Rockchip RK3582 processor, providing powerful performance and diverse interfaces for networking and AI edge computing. This document details the E54C's hardware interfaces, connection methods, and application recommendations to help you fully utilize the device's capabilities.
RK3582 Chip Architecture​
Processor Features​
RK3582 is a high-performance SoC designed by Rockchip, optimized for edge computing and network applications. Its main features include:
  • Powerful Processing Performance: Dual-core Cortex-A76 (2.4GHz) + Quad-core Cortex-A55 (1.8GHz)
  • Network Capabilities: Supports multiple gigabit network interfaces, optimized for network applications
  • AI Acceleration: Built-in NPU with computing power up to 5TOPs@INT8
  • Low Power Design: Suitable for 24x7 operation edge devices
  • Diverse Interfaces: Supports PCIe, USB 3.0, HDMI 2.1, and other high-speed interfaces
RK3582 Internal Block Diagram
RK3582 Chip Internal Architecture Diagram
Design Advantages
  • Network Optimization: Compared to similar chips, RK3582 has been specially optimized for multi-port network applications
  • AI Processing: The built-in NPU can efficiently handle AI inference tasks, reducing CPU load
  • Expandability: Supports PCIe interface, allowing high-speed storage expansion or other functionality through M.2
System Architecture​
E54C adopts a compact and efficient hardware design, integrating multiple interfaces and functions on a single board. The following diagram shows the system architecture of Radxa E54C, clearly displaying the connection relationships between various components.
E54C System Architecture Diagram
E54C Internal System Architecture and Component Connection Diagram
System Components and Data Flow​
The above diagram shows the data channels and connection methods between the RK3582 SoC and various hardware components:
  • Gigabit Network Interface: The 4 gigabit Ethernet ports are extended by the on-board RTL8367RB switch chip (U20), which is uplinked to the SoC's GMAC1 through a single RGMII link
  • USB Interface: USB 3.0 and USB 2.0 interfaces connected to the main processor through independent buses
  • Display Output: HDMI 2.1 interface providing high-resolution output through dedicated controllers
  • Storage Interface:
    • microSD card using a dedicated SDMMC controller
    • Optional onboard eMMC storage connected via high-speed bus
    • M.2 PCIe interface providing high-speed storage expansion through PCIe 2.1 channel
  • Expansion Interface: GPIO pins and other interfaces provide highly customizable expansion capabilities
Data Channel Advantages​
The hardware design of E54C has the following advantages over other similar products:
  • Hardware Port-to-Port Forwarding: Layer-2 forwarding between the 4 ports is done by the switch chip in hardware without using the CPU; traffic that must pass through the CPU shares the same 1 Gbps RGMII uplink
  • High-Speed Storage Access: M.2 PCIe interface extends storage performance through high-speed bus
  • Multi-Interface Parallel Access: Different interfaces use independent data channels, improving overall system throughput
The 4 ports share a single uplink
The 4 RJ45 ports of E54C are not 4 independent MACs brought out directly from the SoC. They are extended by the on-board switch chip (RTL8367RB, U20): the SoC only uses a single GMAC1 (RGMII, 1 Gbps), which the switch chip fans out to the 4 ports.
  • Layer-2 forwarding between ports is done in hardware by the switch chip, so port-to-port traffic runs at line rate without CPU involvement.
  • Traffic that has to pass through the CPU (routing / NAT / firewall / multi-WAN load balancing / VLAN traffic punted to the CPU) shares this single 1 Gbps uplink, so running routing on all four ports at the same time is limited to about 1 Gbps in total, not 4 Gbps.
  • WAN / LAN separation is done in software (VLAN / switch chip configuration, e.g. iStoreOS, OpenWrt) rather than by 4 independent NICs.
Hardware Interface Overview​
E54C Hardware Interface Layout
Radxa E54C Hardware Interface and Component Layout Diagram
External Interface Distribution​
Front Interfaces:
  • 4 Gigabit Network Interfaces (RJ45)
  • 1 USB 3.0 Type-A Interface
  • 2 USB 2.0 Type-A Interfaces
  • 1 USB 3.0 Type-C (OTG) Interface
  • 1 HDMI 2.1 Output Interface
  • 1 DC 12V Power Input Interface (5.5mm x 2.5mm)
Side and Internal Interfaces:
  • microSD Card Slot
  • M.2 M-Key Slot (PCIe 2.1)
  • 14-Pin GPIO Expansion Interface
  • Fan and RTC Battery Interfaces
The following will detail the specifications, connection methods, and application recommendations for each interface.
microSD Card Slot​
Interface Specifications​
E54C is equipped with a standard microSD card slot, supporting hot-swapping functionality, which can be used for system booting or storage expansion.
PINNameFunction Description
1SDMMC_D2SD Card Data Line 2
2SDMMC_D3SD Card Data Line 3
3SDMMC_CMDSD Card Command Line
4VCC_3V33.3V Power Supply
5SDMMC_CLKSD Card Clock Signal
6GNDGround
7SDMMC_D0SD Card Data Line 0
8SDMMC_D1SD Card Data Line 1
9SDMMC_DETNSD Card Insertion Detection
10GNDGround
11GNDGround
12GNDGround
13GNDGround
Usage Guide​
  • Supported Card Types: Compatible with microSD/microSDHC/microSDXC storage cards
  • Recommended Specifications: Recommend using Class 10/UHS-I or higher specification cards for better performance
  • Maximum Capacity: Theoretically supports up to 2TB microSDXC cards, practically tested to support 512GB
Main Application Scenarios​
  • System Boot: E54C can boot operating systems from a microSD card, which is the most common usage
  • Data Storage: Can be used for storage expansion in existing systems (e.g., when booting from eMMC)
  • System Backup: Can be used to backup current system and data
Usage Suggestions
For production environments or systems that need to run 24/7, it is recommended to use eMMC or M.2 SSD as the primary storage and boot device, as they provide better stability and read/write durability. microSD cards are suitable for temporary storage and development testing scenarios.
USB Interfaces​
E54C provides three different types of USB interfaces to meet various peripheral connection needs.
USB 3.0 HOST Type-A Interface​
This is a standard USB 3.0 interface, supporting data transfer rates up to 5Gbps.
1VCC5V0_USB5V Power Output, maximum 500mA
2USB3_HOST_DMUSB 2.0 Data Line Negative
3USB3_HOST_DPUSB 2.0 Data Line Positive
4GNDGround
5USB3_SSRX1NUSB 3.0 High-Speed Receive Line Negative
6USB3_SSRX1PUSB 3.0 High-Speed Receive Line Positive
7GNDGround
8USB3_SSTX1NUSB 3.0 High-Speed Transmit Line Negative
9USB3_SSTX1PUSB 3.0 High-Speed Transmit Line Positive
Application Recommendations:
  • High-speed external storage devices (SSD/HDD)
  • High-bandwidth network adapters
  • USB 3.0 compatible peripherals (cameras, capture cards, etc.)
USB 2.0 HOST Type-A Interface​
E54C is equipped with two USB 2.0 interfaces, supporting data transfer rates up to 480Mbps.
2USB2_HOST_DMUSB 2.0 Data Line Negative
3USB2_HOST_DPUSB 2.0 Data Line Positive
4GNDGround
  • Mouse, keyboard, and other input devices
  • Low-bandwidth peripherals (printers, scanners, etc.)
  • USB 2.0 compatible external devices
USB 3.0 OTG Type-C Interface​
The Type-C interface supports OTG functionality, allowing it to work in host or device mode, while also supporting serial debugging and DisplayPort video output.
A1/B1GNDGround
A4/B4VCC5V0_USB5V Power Supply
A5CC1CC-based Interface Configuration Channel 1
A6/B6DPData Line Positive
A7/B7DNData Line Negative
B5CC2CC-based Interface Configuration Channel 2
A8SBU1Auxiliary Channel 1
B8SBU2Auxiliary Channel 2
A2/B2SSTX+USB 3.0 High-Speed Transmit Line Positive
A3/B3SSTX-USB 3.0 High-Speed Transmit Line Negative
B11SSRX+USB 3.0 High-Speed Receive Line Positive
B10SSRX-USB 3.0 High-Speed Receive Line Negative
A11SSRX+USB 3.0 High-Speed Receive Line Positive
A10SSRX-USB 3.0 High-Speed Receive Line Negative
A12/B12GNDGround
Application Scenarios:
  • Serial Debugging: Can be used for system debugging and configuration, supporting system console access via UART
  • OTG Device Mode: Can connect E54C to a computer as a USB device
  • DP Display Output: Supports connecting to monitors through a Type-C to DisplayPort adapter cable
USB Usage Notes
  • All USB ports share a total current supply of 1.5A, with a recommended maximum of 500mA per port
  • For high-power peripherals, it is recommended to use an externally powered USB hub
  • The display output and USB 3.0 functionality of the Type-C port cannot be used simultaneously; one must be chosen based on needs
HDMI 2.1 Interface​
E54C is equipped with a standard HDMI 2.1 interface, supporting video output up to 8K, with powerful video capabilities for various display applications.
1HDMI_TX2+HDMI High-Speed Data Transmission Channel 2 Positive
2GNDGround
3HDMI_TX2-HDMI High-Speed Data Transmission Channel 2 Negative
4HDMI_TX1+HDMI High-Speed Data Transmission Channel 1 Positive
5GNDGround
6HDMI_TX1-HDMI High-Speed Data Transmission Channel 1 Negative
7HDMI_TX0+HDMI High-Speed Data Transmission Channel 0 Positive
8GNDGround
9HDMI_TX0-HDMI High-Speed Data Transmission Channel 0 Negative
10HDMI_TXC+HDMI Clock Signal Positive
11GNDGround
12HDMI_TXC-HDMI Clock Signal Negative
13HDMI_CECConsumer Electronics Control Signal, for inter-device control
14NCNot Connected
15HDMI_SCLDDC Clock Line, for EDID information reading
16HDMI_SDADDC Data Line, for EDID information reading
17GNDGround
18VCC5V0_HDMI5V Power Output
19HDMI_HPDHot-Plug Detection Signal
Supported Resolutions and Formats​
The HDMI 2.1 interface supports output in various resolutions and scales:
  • 4K@60Hz: Most common high-definition output mode, suitable for most modern displays
  • 4K@30Hz: For older displays or TVs
  • 1080p@60Hz: Full HD mode, suitable for standard HD displays
  • 8K@30Hz: Highest resolution mode, supporting next-generation 8K displays
Supported color formats:
  • RGB 444
  • YCbCr 444/422/420
  • HDR10 support
  • Digital Signage: Displaying information or advertisements in public places
  • Monitoring Systems: Displaying multiple video surveillance feeds
  • Visualization Interfaces: Displaying system status and network traffic data
  • Media Player: Connecting to TVs or displays for multimedia content playback
Usage Recommendations
  • HDMI and Type-C (DisplayPort) can be connected simultaneously, but during use, one will be selected as the output based on system configuration
  • It is recommended to use high-quality HDMI cables to ensure stable transmission of high-resolution signals
  • Although 8K is supported, 4K@60Hz is sufficient for most practical applications
Gigabit Ethernet Interfaces​
E54C is equipped with 4 gigabit Ethernet ports, which are the core functional components of the product, supporting various network application scenarios. The following is the pin definition for the standard RJ45 interface:
1ETH_TXPGigabit Ethernet Transmit Data Positive
2ETH_TXNGigabit Ethernet Transmit Data Negative
3ETH_RXPGigabit Ethernet Receive Data Positive
4NCNot Connected
5NCNot Connected
6ETH_RXNGigabit Ethernet Receive Data Negative
7NCNot Connected
8NCNot Connected
Gigabit Network Controller​
The 4 gigabit network interfaces of E54C are extended by the on-board RTL8367RB switch chip, which is connected to the gigabit network controller (GMAC1) integrated in the Rockchip RK3582 SoC via RGMII. Related features include:
  • Full-Duplex Gigabit Ethernet: Each port supports 10/100/1000 Mbps rates
  • MDI/MDIX Auto-Detection: Automatically identifies straight-through and crossover cables
  • IEEE 802.3 Compatible: Supports standard Ethernet protocols
  • Hardware Flow Control: Supports IEEE 802.3x flow control
  • Internal MAC Address: Each port is assigned an independent MAC address
Network Configuration Scenarios​
The four gigabit Ethernet ports allow flexible configuration of various network topologies:
1. Multi-WAN Router Configuration
Multiple ports can be configured as WAN interfaces to achieve:
  • Multi-line load balancing
  • Link aggregation
  • Multi-ISP backup connections
2. Network Hub Configuration
Configure all ports in switch mode:
  • Network segmentation (VLAN)
  • QoS priority control
  • Port mirroring and monitoring
3. Combination Mode
The most common configuration: 1 WAN + 3 LAN ports:
  • 1 port connected to upstream router/modem
  • 3 ports used for internal network device connections
Usage Recommendations​
  • It is recommended to use CAT 5e or higher specification Ethernet cables to achieve full gigabit performance
  • Multi-WAN configuration requires specialized routing software support, such as iStoreOS or OpenWrt
  • Pay attention to heat dissipation issues when running high-traffic network applications
Professional Tip
For applications requiring powerful network performance (such as enterprise routers, gateways, etc.), port bonding can be configured to increase bandwidth and reliability. These advanced features can be easily configured in iStoreOS or OpenWrt.
M.2 M Key Interface​
PINName
1GND
2VCC3V3_PCIE
3GND
4VCC3V3_PCIE
5GND
6NC
7GND
8NC
9GND
10NC
11GND
12NC
13GND
14NC
15GND
16NC
17GND
18NC
19GND
20NC
21GND
22NC
23GND
24NC
25GND
26NC
27GND
28NC
29GND
30NC
31GND
32NC
33GND
34NC
35GND
36NC
37GND
38NC
39VCC3V3_PCIE
40NC
41VCC3V3_PCIE
42NC
43GND
44NC
45NC
46NC
47GND
48NC
49GND
50PCIE_CLKREQ_N
51GND
52PCIE_WAKE_N
53GND
54PCIE_REFCLK_P
55PCIE_REFCLK_N
56NC
57GND
58PCIE_RX_N
59PCIE_RX_P
60GND
61GND
62PCIE_TX_N
63PCIE_TX_P
64GND
65GND
66NC
67NC
68PCIE_RST_N
69GND
70NC
71GND
72NC
73GND
74NC
75GND
M.2 SSD Support​
E54C's M.2 slot supports M.2 2280 NVMe SSDs via PCIe 2.1 interface (1 lane, x1), with the following specifications:
  • Interface Type: PCIe Gen2 x1, theoretical bandwidth up to 5Gbps
  • SSD Form Factors: Compatible with M.2 2280 (80mm length)
  • Protocol Support: NVMe protocol SSDs are supported
  • Power Supply: The slot provides 3.3V power
Performance Optimization​
  • For optimal I/O performance, it's recommended to use high-quality NVMe SSDs with good sequential read/write capabilities
  • The device firmware is optimized for popular NVMe SSD models, ensuring maximum compatibility
  • In performance-critical applications, the disk IO scheduler can be adjusted for specific workloads
GPIO Expansion Interface​
The 14-pin GPIO header provides access to various low-level interfaces:
PINName
1VCC_3V3_S0
2VCC5V0
3I2C7_SDA_M3
4VCC5V0
5I2C7_SCL_M3
6GND
7UART8_TX_M0
8SPI0_MOSI_M2
9UART8_RX_M0
10SPI0_MISO_M2
11I2C6_SCL_M0
12SPI0_SCK_M2
13I2C6_SDA_M0
14SPI0_CS0_M2
Additional Interfaces​
  • Fan Connector: 2-pin connector for connecting a 5V cooling fan
  • RTC Battery Connector: For connecting a backup battery to maintain the real-time clock
  • Recovery/Reset Buttons: Located on the board for system recovery or reset operations
Hardware Design Considerations​
Thermal Management​
E54C's aluminum case provides excellent passive cooling. For high-load applications:
  • Ensure adequate airflow around the device
  • For intensive workloads or hot environments, connect a fan to the dedicated fan header
  • Keep ambient temperature below 35°C for optimal performance
Power Requirements​
  • Input Voltage: 12V DC (±5%)
  • Power Consumption:
    • Idle: ~5W
    • Typical load: ~8-12W
    • Full load with NVMe SSD: up to 15W
  • Always use the recommended power adapter (12V/2A or higher)
Reliability Features​
  • Overvoltage protection
  • Overcurrent protection
  • Thermal throttling to prevent overheating
  • Watchdog timer for system stability
Development Recommendations​
For optimal use of E54C's hardware capabilities:
  • Use iStoreOS or OpenWrt for network-focused applications
  • Debian for general computing and AI development
  • Custom Linux builds for specialized applications
  • Take advantage of the NPU for AI processing, freeing CPU resources for other tasks
Conclusion​
The Radxa E54C provides a powerful platform for edge computing and networking applications, with its combination of processing power, network interfaces, and expansion capabilities. This hardware interface reference will help you utilize the full potential of the device in your projects.
