Depth-Anything Example
This document describes how to use the QAI AppBuilder Python API to run inference with the Depth-Anything depth estimation model on Qualcomm® Hexagon™ Processor (NPU).
Supported devices
DeviceSoC
Fogwise® AIRbox Q900QCS9075
Install QAI AppBuilder​
Run the sample​
Install dependencies​
pip3 install requests tqdm qai-hub py3-wget Pillow torch torchvision opencv-python-headless matplotlib
Run the script​
    cd qai-appbuilder/samples
input image
  • Run inference
    python3 ComputerVision/Depth_Estimation/depth_anything/depth_anything.py --chipset 9075
  • Example result
output image
The first run downloads the model via Qualcomm® AI Hub (network-dependent). You can also use the launcher from samples:
python3 run_inference.py --model depth_anything --args "--chipset 9075"
