Facial-Landmark-Detection Example
This document describes how to use the QAI AppBuilder Python API to run inference with the Facial-Landmark-Detection facial landmark detection model on Qualcomm® Hexagon™ Processor (NPU).
Supported devices
DeviceSoC
Fogwise® AIRbox Q900QCS9075
Install QAI AppBuilder​
Run the sample​
Install dependencies​
pip3 install requests tqdm qai-hub py3-wget Pillow torch torchvision opencv-python-headless scikit-image onnxruntime
Run the script​
    cd qai-appbuilder/samples
input image
  • Run inference
    python3 ComputerVision/Face_Recognition/facemap_3dmm/facemap_3dmm.py --chipset 9075
On AIRbox Q900 the sample may prefer the ONNX float model (requires onnxruntime). A successful run writes output.jpg and may print ONNX model inference time: ... ms.
  • Example result
output image
The first run downloads the model via Qualcomm® AI Hub (network-dependent). You can also use the launcher from samples:
python3 run_inference.py --model facemap_3dmm --args "--chipset 9075"
