Qwen VL Sample
This document describes running the upstream Qwen VL multimodal vision-language sample with QAI AppBuilder on Linux aarch64 (Gradio UI or in-script Inference).
Supported devices
DeviceSoC
Fogwise® AIRbox Q900QCS9075
Install QAI AppBuilder​
Run the sample​
Install dependencies​
pip3 install "transformers==4.57.0" qwen-vl-utils gradio Pillow torch torchvision opencv-python-headless
qwen_vl.py imports Qwen3-related modules, so you need transformers ≥ 4.57 (includes transformers.models.qwen3_vl). Also install qwen-vl-utils.
Prepare the model​
This sample does not auto-download Qwen weights via --chipset / AI Hub. Follow the upstream README for a pre-quantized package, for example Qwen2-VL 2B:
cd qai-appbuilder/samples/Multimodal/qwen_vl
wget -c https://www.aidevhome.com/data/adh2/models/suggested/qwen2vl2b.zip
unzip -o qwen2vl2b.zip
# Example extract layout: ./qwen2vl2b/ (veg.serialized.bin, weight_sharing_model_1_of_1.serialized.bin, tokenizer.json, ...)
The zip is about 1.8 GB; extracted size is about 2.6 GB. Reserve disk space accordingly.
Run the script​
  • Enter the sample directory and set ADSP (same as the install page)
    export ADSP_LIBRARY_PATH=$(python3 -c "import os, qai_appbuilder; print(os.path.join(os.path.dirname(qai_appbuilder.__file__), 'libs'))")
  • Start the Gradio web UI (default 0.0.0.0:7861)
    python3 qwen_vl.py --model qwen2 --path ./qwen2vl2b --host 0.0.0.0 --port 7861
Open http://<device-ip>:7861, upload an image, and enter a question.
  • Optional headless check: after loading the model, call Inference once. On AIRbox Q900, with sample image vlm_demo.png and prompt Describe this image in one sentence., a response similar to the following was observed:
A webpage with a form for uploading files.
warning
run_inference.py --model qwen_vl does not replace model download. The entrypoint requires --path to the model directory and has no --chipset 9075 argument.
If TBB is installed, some setups set LD_PRELOAD to libtbb.so per the upstream README; on Q900 a one-shot inference also succeeded without it.
